[Build Thread] BaylorCorvette's Conquest For The Ultimate American Track Car
Sr.Random input generator
Interesting that you say that, because even on fresh NT01's I thought the handling just wasn't there and perhaps like you suggested the spring and/or the sway bar may be the problem when going to more tire. I've got the LG front sway in my garage that I'll be installing soon, however the rear sway is staying OEM so I can stay eligible for stock class in SCCA. However, I'm thinking this time next year I'll be looking to order the LG coilovers.
You could obviously try Z07 springs, but why bother, your shocks' tune would be off. Using sway bars is a good idea, but during my whole track experience with various cars, I was always told that the sways should be used to fine-tune, not fix issues, so that also feels a bit counter-productive.
This is a long discussion, and I'm sure we will have more of it : ) I have been staying a bit silent on my own build thread regarding these findings, since I would like to attend more track days first with my current setup to validate a few findings. It has been proving hard to do so, though, since fall/winter season is here : (
Well guys....(X25 and BaylorCorvette), I've been following you both for a while on Camaro5 and see you are now on here. I just upgraded this week from a 13' 1LE to a '14 Z51 M7. I love the track discussion (and videos) and am looking forward to seeing how your build progresses.
While I want to get a feel for the car on the street for a bit before I book a track day, I'm looking forward to feeling the difference between my former 1LE and the Corvette. Your first impressions post on this thread was very enlightening and I can't wait to see for myself.
This car is teaching me the impact of matching tire changes with suspension changes. I'm looking forward to trying my car out at my other local tracks : )
Welcome to the club umiami2312 , you'll love the car. The Corvette is such a point and shoot vehicle (assuming the rear caster is aligned properly!)
If that isn't the truth I don't know what is! The 5th gens (at least the ZL1) was way much less sensitive to tire size changes.
This leaves me still in a dead spot. I've tracked the stock PSS and ate them up in three track events, which didn't lend to many miles driven. My search is on for a wheel/tire track package and all this info is making it harder to decide what to do.
I have to say, that I enjoyed the way my car handled running the LG bars and everything else being stock (mag ride).
But, I don't know what to do for wheels/tires for the track! I came close to purchasing 18x10.5/315 squares off of descartefool, but wasn't sure that was the way to go. Now, I am totally lost!
Congrats on your new personal best, Baylor! Looking forward to hearing about lowering your times further with the Pirelli scrubs. You'll definitely want to install the LG sways prior to the scrubs, though, or you'll be further disappointed in the handling. Not sure about the impact on a non-mag ride car, but the LG sways reduced the roll and understeer by about 50% in my mag ride car with no other suspension changes, and with the scrubs, the car was a ton of fun!
Glad you gave feedback about scrubs on OEM sways & LG Sways. I would only assume that scrubs and OEM sways would be worse on a non mag ride car than on a mag ride car since the dampers aren't adjusting to help adept to the scrubs. I'm going to be in an interesting situation, since I'm only doing the front sway bar (to maintain SCCA eligibility), the car is going to understeer more with just the front, so I suspect that my set up is going to suck on scrubs for the road course. If that's the case I'll just do the rear sway and coil overs this time next year and just compete in the unlimited class in SCCA
If I didn't insist on making 315/325 work, and revert back to 275/305, I would never know what I would be missing! Most of my confusion is coming from the feedback from forum members here, where they swear by the stellar performance they got with their 315/30/18 square NT01 or similar R7 setups, where noone could even come close to them at the track. Knowing what I know now, at least for FE3, they probably didn't realize how much better it could be, and/or their local competition was not good enough to make them realize their vulnerabilities.
It doesn't stop with the forum members, either. Take a look at this vendor post:
https://www.corvetteforum.com/forums...rformance.html
Reading all this, since almost everyone who use Hoosiers use wide tires, wouldn't you think that T1 works well with Hoosiers? Well, I know for a fact now that the springs these T1 shocks are designed for will be way too soft for the Hoosiers, and any other spring will not be matching the shock valving, so the answer is a big resounding NO. You might say they take sway bars into account, too. Again, the answer is still NO: T1 sway bars that I had were not able to save my handling issues.
Based on my experience, I don't think 315s would work well on stock suspension. Now, I don't know how the FE4 behaves with stickier tires, but I've already read about FE4 being even more sensitive, so I doubt it would be good. In short, yes, you can make an excellent handling car with those tires, but you will have to work on the suspension. If your car has MR, then I think you should consider LG sways (not Z07 since you want square balance), Z07 springs + DSC controller for the matching shock tune; that might make an incredibly-well-handling car.
5. GM T1 kits or LG sway bars. Take your pick and we will install. The improvement is large!
6. Shocks. If you have the MR setup they work well. We also have Penske shocks with helper springs if you want more.. Also a GM T1 non adjustable shock that works well.
12. Hoosier Tires. We have a selection of A7 and R7 used Hoosiers that are an easy handling upgrade..
I have the LG sways. And am waiting on the DSC controller. However, I still don't know what to do for wheels and tires! I'd like to run the NT-01. Porsche GT3 driver I know gets a ton of track miles off his. I was really surprised when I wore the inside of my PSS's to slicks after only three track days. And now reading about Baylor's experience with the NT-01 it has me guessing. It looks like wider is better... just wish there was an easy answer!
It really is surprising that I only got three good days (~400 track miles) out of the NT01's. The instructor that I was talking to was shocked, he has an FRS and the NT01's last nearly a season for him. On my ZL1 I was getting about 5-6 days when I was running a 305 square NT01 set up.
I am thinking of buying GT2 wheels from LG that are a 18x9 and 19x10.5. I want to run as fast as possible on the track for a reasonable price and have looked at Hoosier R7, Nt01 and R888 and would consider scrubs if I can find them. I am open to both tire and wheel combo's but just want to keep a reasonable price. For track only, any suggestions?
#33
Really comes down to how much you want to spend on wheels and tires. I went the cheaper route and bought TSWs Corvette brand wheels which I think is Cray or something similar (I just landed in Vegas and I'm currently sitting in a restaurant eating a late lunch and then I'm driving to Spring Mountain). I'm sure LG wheel combo is great but I have no issues with my wheels, fitment or otherwise. Tire wise, like I've mentioned I'm not happy with the NT01s. I rain a faster time on the stock PSS run flats on only my second lap out with them. Mean while I had maybe 500-600 track miles on the NT01s. Point being I didn't know what to expect on the PSS and was going easier than I was on the NT01s. Now I don't know if it is because I went wider with the NT01s front and back and the car didn't like that or what. But I'm going to pick some people's brains at Spring Mountain the next couple of days.
My one piece of advise is to not run slicks until you master a DOT tire.
#34
On a related note, I think Cray Spiders (which I believe are what you have) are great wheels with low weight, much lower than LG's offering, but unfortunately they do not clear C7 Z06 iron brakes. If you intend to upgrade your brakes in future, this would be an issue.
#35
The corvette knock offs would be the cheapest however I want a wider wheel as I would at least like to run a 275 front and 305 rear and the stock wheel width is stretching it a bit. The GT2 is a half inch wider than stock and doesn't require any spacers to clear the z06 brakes. I figure after a season on them I will consider upgrading to something like x25 has as I would like to run as wide a front tire as possible without hitting the fenders. I am bummed to hear about the NT01 as that was my first choice. I can get R888 in either a 285/30/18 or a 275/35/18 then match it with a 305/30/19. The 30 series front puts me at 1.068 ratio to the rear with the 35 series at 1.03. Some guys seem to like the R888's but some say they just stick ok the R888R is better. I ran Hoosier R6's on my c6 z06 and really liked them a lot as they stick like glue. So I am considering the R7. They are more expensive and won't last as long. I've also looked at the R888R. I have heard better remarks about them vs the R888. They are only available in a 275/35/18 or a 295/301/18 which I am worried might be too wide. For rears they also come in a 305/30/19. Maybe the R888R's in 275 and 305 would be the way to go for now and when it's time to replace the tires, consider if I want to go to the next level with slicks and more suspension mod's.
#36
Don't lose your faith in NT01s just yet. I also tried 275 / 305 NT01s, and I also didn't like the performance, as in, I could not hit times I should. When I later switched to 315/325 NT01s, the traction has increased so much, that the car started leaning substantially in corners, eventually rubbing on all 4 corners. If you think abou it, leaning too much due to traction is a good problem to have : ) Later, I switched to coilovers with stiffer springs that were adequate for these tires, and my time at the very same track dropped by 6 seconds.
Jury is still out, and I'm sure we will dig this further this next season. That said, I can tell from my and my brother's experience that R888s are vastly inferior tires, at least in our experience. I am looking forward to hearing news about the R888Rs, but some forum posts claim it's the same compound with different thread pattern, which would be disappointing. We shall see.
#37
Has anyone just put Cup 2's in the stock Z51 sizes on and seen how that works as an option for the track?
#38
2020 Corvette of the Year Finalist (track prepared)
C7 of Year Winner (track prepared) 2019
Op, seeing your times I'm noticing that you're multiple seconds off pace of a completely stock Z51 at both TWS & MSRH.
Why would you want to be making modifications (obviously other than brake pads and cooling)
I'm not trying to be rude at all, just to get a better understanding.
ETA: I'm off pace too so im in no competition. I'm currently at 1:58 @ TWS & 1:48 @ MSRH.
Also, were you at the HPD autox this last summer I think on the 9th of september? If so I rode with you.
#39
#40
Yes that was probably me. That's about the time I started running with SCCA.
