416 or 427 Stroker? Please chime in.
I am looking into upgrading to a stroker kit but I am not familiar with the best options available on the market. I have done a cursory review and noticed Katech is developing a 427 stroker, Ben@Weapon X has one available, and Texas Speed and Performance sells a 416 stroker.
That said, is there anybody here who upgraded to a stroker from any given company and can you tell me how it is working out for you? I'm looking for a reasonable price point and good performance.
Thanks for your input!
Once you go past 416 you need to have sleeves installed. Which raises the cost. But more displacement is better for making power, it just costs more.
NinjamanZ51 (06-06-2016)
http://www.texas-speed.com/p-3586-ts...y-package.aspx
Last edited by NemesisC5; 06-06-2016 at 01:32 PM. Reason: Added link for reference
Received 1,762 Likes
ttt
If me I have had a 408 ls2 motor then went with a RHS 427 build. both with a YSI are a F1X blower on it.
If I was going with a blower set up I would stay with a stock block ci motor. That said to get a little more power on a N/A motor look at tx speed 416 set up with a good set of heads on it. Robert
Here are some numbers for comparison:
L88 and original ZL1, 4.25" bore x 3.76" stroke, big block engine
LS7 engine, 4.125" bore x 4.00" stroke, staggered bores
Gen5 LT1 engine, 4.065" bore x 3.622" stroke
Wow, the Gen5 LT1 is a fairly short stroke engine. Then why is it a high torque engine ? A high torque cam ?
To make it a high RPM engine just build it and cam it without increasing stroke
After doing some more research, I'm thinking a 416 is probably the best bet for me. I'm guessing TSP is the only vendor offering a 416 kit, correct? Thanks, y'all!
If any forum vendor wants to chime in, feel free to do so!
I believe the 427 LS3 strokers have a 4.1" stroke crank as opposed to 4.00"
Ninjaman, yes I was a contributor on GenCoupe when I owned one. But I wanted (a lot) more power so I ended up with a C6. You?
That's correct. The longer stroke makes the skirt of the piston protrude too far below the cylinder. It rocks the pistons, and causes premature wear, or worse. The fix is sleeves.
I live in the Phoenix area and will go with Cordes Performance Racing (CPR), when the time comes. CPR has an excellent reputation with the Vette guys here. CPR has built several C7 416's. I don't know if they done any sleeved 427's or would even recommend that build over a 416.
NinjamanZ51 (06-16-2016)
It made 668 rwhp on 8 psi boost on a very safe tune. It has a TSP stage 1 cam, ported heads, methanol injection, headers, it only has 9.5 to one compression though I would get 10.5 if doing it again. The blower is off of it now waiting to be rebuilt. Holler if you want to see it.
wat do u guys use for main and rod bearings for 416 lt1's wld the old style work? Or shld i use lt4 ones and lt4 head gasket this is for a 416 truck twin turbo truck
<br >
Picture for attention
