M7 trans fluid, rear end oil, synthetic ???
Does anyone know if the M7 trans fluid is 100 % synthetic from the factory fill ? and same question on the 75/90 gear oil in the rear end, is it 100 % synthetic oil (non ELSD)??
Sr.Random input generator
The factory fill diff fluid's bottle does not state that it's synthetic anywhere on it. That said, I don't know if there is any approved product besides OEM part # for diff fluid. For transmission, you could choose any brand. I went with Amsoil's signature ATF
BJ67 (07-08-2016)
I went with Redline D4 ATF in my M7 transmission and it feels quite a bit better than it did with the OEM fluid. For the rear differential, I stayed with OEM rather than having to mess around with aftermarket synthetic fluid + limited slip additives.
Here's a write-up I did on the procedure: https://www.corvetteforum.com/forums...d-service.html
And a few other related threads I've started to reference on the matter:
https://www.corvetteforum.com/forums...tr-6070-a.html
https://www.corvetteforum.com/forums...7-shifter.html
BJ67 (07-08-2016)
I would just stick with the GM approved fluids.
I have friends that switched to synthetic trans. fluid back when I had a C5 and it actually shifted worse... They changed back to the GM fluid and it smoothed out...
Without knowing if compatible with ALL internals, I would not go to an aftermarket fluid.
The problem is rather with the diff fluid. GM's LS gear oil is not certified by most manufacturers, though same fluid is recommended for C5/C6 as well as many other cars, and they do work with regular diff fluids from other manufacturers with no issues reported.
Makes sense. On my last C6 Corvette, I went with Amsoil's 75W-110, which already has the additive, too, and is also more stable at high temps than a regular 75W-90, while being fully compatible with 75W-90 (75W-110 was released later to address concerns about 75W-90 being too wide of a spec, and is more focused on high temp stability and performance). For my C7 Z51, I will use the OEM fluid for the time being, but will replace it often. I might switch to another fluid later on, once I get to know the car well, and make enough lap times with the OEM fluid. Once I have the data, I can then use another fluid, and see if I screwed myself up : )
Received 1,984 Likes
I threw in Amsoil in the rear end. Problem is how do I know it is any better or worse? Assuming I have no mechanical issues? I'm thinking of changing the trans out........ I can tell better shifting or not on the tranny. Friend is an amsoil dealer and the high mile cars he has make me a believer.
