How to safely remove center caps on the C7?
Old 08-23-2016, 03:47 PM
my2016vette
my2016vette's Avatar
Default How to safely remove center caps on the C7?
Suggestions on how to safely remove the center caps on the C7?
Old 08-23-2016, 03:58 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
remove the rim from the car then push it out from the back side. I really am not kidding you here..
badhabit_wb (06-20-2020)
Old 08-23-2016, 09:11 PM
Z06 1of38
Z06 1of38's Avatar
Take a piece of paper.
Laminate it (most offices have a laminater)
Bend it to slide under cap.
Pop cap off
I used a gym membership card.
Old 08-23-2016, 09:31 PM
NTMD8R
NTMD8R's Avatar
I agree.... easiest and safest.
Old 08-23-2016, 11:11 PM
owc6
owc6's Avatar
Received 4,185 Likes on 2,679 Posts
There is the velcro sticky-back version that some swear by and also the dental floss version that others say works wonderfully, w/o have to remove the wheel.
Old 08-23-2016, 11:18 PM
robert miller
I have never seen a center cap that has no small edge are cut out in it that you could not get a small screw driver into and just twist it out really easy.
My stock rims & also the aftermarket wheels I have on it you just cant do it and feel safe about doing it. Plus I have Black chrome after market on the car now. It was a bear for me to get the center caps in place. Just stupid to me taking a chance of doing damage to a rim.
Old 08-24-2016, 11:46 AM
C7-Beast
C7-Beast's Avatar
Dental floss or fishing line if you don't want to remove the wheels. I did it and it worked great.
Old 08-24-2016, 04:45 PM
my2016vette
Thanks all,
I just used an old hotel plastic key and it worked perfect.....took 4 minutes to do all four!
The following 2 users liked this post by my2016vette:
Avanti (06-08-2020), joemosfet (08-24-2016)
Old 08-24-2016, 06:04 PM
joemosfet
joemosfet's Avatar
^ Good to know its easy to remove center caps without damaging or having to remove the wheel. At car shows, I like for the logo to be right-side up.
Old 08-26-2016, 11:52 AM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
I like it pointing at the valve stem.
Bill
Old 06-07-2020, 12:08 AM
GrandSport223
GrandSport223's Avatar
I found this thread and just had to ask, will a plastic hotel key be skinny enough to get in between the centre cap and the rim?? My C7 GrandSport came from the factory with the punisher Corvette logo and it also came with the extra racing flag logo. Racing flag logo is still in the plastic covering never used so I think I want to change them this weekend.
Thanks all,
Old 06-07-2020, 12:11 AM
owc6
owc6's Avatar
Only if you found the car in a hotel parking lot, and found a key in the trash can right outside the lobby, then, in that case: go for it. Watcha got to lose?
Old 06-08-2020, 08:09 PM
Avanti
Avanti's Avatar
Received 5,187 Likes on 3,439 Posts
Any old credit card-like thingee or promotional plastic piece from some ads will do the trick. I actually had my doubts, even after watching the guy on a vid do so with ease... until I tried it. It worked first time and every time like a charm, but can bugger up the edge of the card.
Old 06-08-2020, 09:21 PM
GrandSport223
well I may have to try that. I’ve seen guys use a suction cup on other rims to pop out the centre cap and it seem to work good and the two sided Velcro and you just pull it off with pliers I’ve seen that video as well.
Old 06-09-2020, 08:24 AM
bluegoatee05
bluegoatee05's Avatar
The old hotel key trick works perfectly. It is plastic as well, so it won't mess up the surface of the center cap. I wouldn't personally use a screwdriver for fear of messing up either the rim or the cap.
Old 06-15-2020, 04:48 AM
GrandSport223
Well I did the hotel key trick to pop out the centre caps and it worked like a charm. the odd centre cap Was giving me a bit of a hard time to pop out but eventually I got it.
Old 06-18-2020, 12:20 PM
BostonVette
BostonVette's Avatar
Bill
Damn, I do the same thing...
It's kinda OCD but that's who we are
Old 06-22-2020, 08:21 PM
BigBoyRon
BigBoyRon's Avatar
I like it pointing to the "Corvette" script!
To How to safely remove center caps on the C7?
Quick Reply: How to safely remove center caps on the C7?
