C7 3:90 & 4:10 Gears
I'm Batman..
Pro Mechanic
Justin - Not to jump the gun here, but I notice you currently offer a number of rear end gear sets for earlier vintage Corvettes. Do you distribute gear sets to installation shops around the country? Just trying to figure out where I'm going to need to travel to to get an installation done when C7 gears are available - I'm in SW Florida.
Platinum Supporting Vendor
!00%DISVET (12-27-2016)
Cryo treating will not eliminate the problem.
The problem has a fix, and that is a Wavetrac differential. Wavetrac is working on a design that will eliminate the problem.
Not to fuel the flames, but look what I have.
This would be the 4.10 variety and a 3.90 sitting next to it. We should have it in a car testing maybe late next week. Will keep you all posted. I know everyone has been patient, we have been working on this for over 3 years. It will be sooner rather than later and the C6ZO6 will be following up.
Justin
Zip Products
Justin
Zip Products
Justin,
1) Who is manufacturing the gears?
2) Where are they made?
3) What is the gear material?
Thanks.
So with that being said, yes cryo works very well, we have had diffs in allot of race cars with posi units in them and I have NEVER had one wipe a set of spider gears. For those that want to move up, we have the Quaife diff as well.
Yes, they have been inventing that for the last decade, do they have a release date yet?
Dave,
I was at the PRI Show in Indianapolis this past Thursday and Friday.
I stopped at the QUAIFE booth and talked to Michael Quaife about their progress on designing and building a Quaife differential for a C7 Corvette. He stated to me that they have not been able to do any work yet, because there are no C7 Corvettes that they can disassemble to measure.
So, a Quaife differential for a C7 is quite a while away.
Dave,
I stopped at the QUAIFE booth and talked to Michael Quaife about their progress on designing and building a Quaife differential for a C7 Corvette. He stated to me that they have not been able to do any work yet, because their are no C7 Corvettes that they can disassemble to measure.
#33
Dave,
The following are some pictures of a C7 differential where the spider gears have failed:
This is the differential assembly with the side cover removed
This photo shows the differential, with the axle shafts
The three pictures above show the broken spider gears and the damage they do to the differential housing.
The above two pictures show the pieces of the broken spider gears and the pieces of a broken gear versus a new gear.
Cryogenically treating the C7 spider gears is not going to eliminate this failure for in high horsepower cars.
#34
Dave,
Not trying to get into to a contest with you here, but we build ALLOT of Getrag diffs. So when you say High HP what are you talking about? I have not seen a C7 with a failure yet on the spider gears, I have seen a R&P fail in one. The C7 does have a different vendor then the C5/C6 had it could very easily be a hardness issue that could be related to a batch of gears. Just like it was in the early production of C6 ZO6 axles. If the gear is to spec, then they should be fine depending on how much power you are talking about, but at that point the entire diff would be in question. Don't think for one second that you can't break one of the little spider gears inside a Quaife or Wavetrac or what ever flavor of part you are wanting to use. We just sent 1300+ Hp through a C6 ZO6 diff and it so far is living just fine. You couple the right HP and the right tires and you have allot more to worry about then spider gears. That picture looks like the inside of the hydraulic diff, so does Wavetrac even make the new carrier for the hydraulic unit?
#35
I have not seen a C7 with a failure yet on the spider gears. - As DAVE01GT stated in his post, he has had three C7 differentials fail because of spider gear loss of integrity. Perhaps he will tell us how much power he is applying to the differential, and what tires he is using.
The C7 does have a different vendor then the C5/C6 had. - You are correct, the C7 has a different vendor for their differential. Linamar, a Canadian company, has replaced GETRAG.
That picture looks like the inside of the hydraulic diff, so does Wavetrac even make the new carrier for the hydraulic unit? - Some of the C7 Corvettes have an Electronically controlled differential. This unit was the standard differential. You can tell the difference by the longer of the two axle shafts. See the picture below. The long axle shaft with the extra, larger spline is from the electronically controlled diff. The other shaft is from the standard diff. The short axle in the picture is common to both units:
#36
Pumba,
Not really asking you any questions. I asked about that one because in the picture of the side axle gear I couldn't tell which one it had. Wavetrac called me today to give me updates on their part numbers and said they had a C7 application but didn't know which one. I am going to assume it will be the standard. I have had a C7 Diff apart but the ELECTRONIC Controlled and the Standard since mid/late 2013. Like I said earlier, I have not seen in any and I don't really count what you see on the internet most of the time. It very well could be a hardness issue just like the early ZO6 had. I ran our C7 really hard right out of the gate and it has had no issues what so ever. I know of a very early failure on a C7 but it was due to an extreme situation and it was not the spider gears that failed. The only reason I posted to your reply is because you commented on one of my posts about cryo not working. Your in Michigan, ask Mr. Buttermore how his differential has done for him.
#39
#40
