Most all synthetics can now meet the dexos spec.
I use Valvoline Synpower along with a WIX filter.
I had problems with AC Delco filters leaking at the gasket, I think because for awhile they made the base plates too thin. I switched to WIX and have never had a problem
+1, I've always had great results with WIX filter. Despite the fact that my engine was still very new, the oil results were great.
Oil analysis results are in! Mobil1 0W-40 seems to work great
EDIT: We should also mention here, that WIX has also worked great! It provides excellent filtration, considering the engine is still very new, and could have insoluble particles in the fluid.
WIX Gold filter here also from about 15 other filters it came out on top. Robert
