What is a good AFR @ WOT naturally aspirated
Right now, fully warmed up and just cruising at a steady 2000 RPM, my AFR is 14.75. I am going to do a second gear WOT pull from maybe 2000RPM to redline to see what the AFR is.
My concern is its lean , AFE CAI, lowered water temp 180 stat, cooled and dedicated fabricated air intake path from rf grille opening to aircleaner filter, have the hot water hoses and intake tube insulated for less heat transfer ,a piece of insulation under the throttlebody (on top of the water pump housing) all the plastic cover and insulator blanket off the intake manifold. I am sure I have created a cooler intake charge and I believe lean fuel-air mixture and cool inlet at WOT could be a loss of HP and a recipe for detonation.
What would be a safe range AFR At WOT?
St. Jude Donor '13-'14-'15
The commanded AFR during P/T is a 14.11 only for the 1st time this rich on the DI C7 engine In years previous the P/T AFR was at STOICH which is 14.68
14.75 would indicate it is somewhat lean at P/T However remember when lifting off the throttle the DFCO system kicks in so you get crazy lean AFR's that can be mis interpreted
DFCO is "deceleration fuel cut off" where to save gas the ECM shuts off the fuel and you get very lean readings --so make sure when you are reading AFR's at P/T it is not after decelerating
Now that being said --- I installed the same AFE CAI----This system added so much air that i had to ADD aprrox 13% of fuel via the MAF to compensate at P/T
As a matter of fact Diablo now has a specific AFE CAI tune that does the compensation for you
At WOT so may variables can come into play--the only way to get the AFR correct is to use a wideband 02---Typically at WOT these cars are set up rich anyway--so even a 10-13% leaness will still be safe--just make more HP !!! Older C5-C6's would run best and safe with a WOT AFR of about 12.7-12.8 However the new DI engines run best with a slightly leaner WOT AFR like 12.9 to 13.0
Only way to verify WOT fuel is using a wideband and a tuner that has experience with the new DI engines
BJ67 (09-25-2016)
Received 1,194 Likes
St. Jude Donor '15
The wideband reading is based around a stoich value of 14.7. It actually reads lambda (all widebands do), not AFR. It's just multiplying the lambda reading x 14.7 because that's what most everyone uses and it used to. This is why tuners should be using lambda and not AFR.
GM started using 14.1 for their stoich AFR values as that's what most pump fuel is now. In closed loop it doesn't actually change the AFR. It's going to run at lambda = 1 regardless of whether you have E0 or E10 in it and whether the stoich AFR table is set to 14.7 or 14.1.
Bottom line at part throttle you're running at lambda = 1 so nothing scary there.
What are you seeing @ WOT?
Also, there is a MAF and IAT that will see if more and/or cooler air is coming in. It's not like the sensors are there for looks--I'd be surprised if it's too lean. DI engines should be ran leaner anyways.
BJ67 (09-25-2016)
Almost all modern cars have stoich set to 14.1 to account for E10 gas.
BJ67 (09-25-2016)
St. Jude Donor '15
Sounds like you're reading commanded AFR and not actual. You can't read actual without a wideband. The factory o2 sensors can only tell if you're richer than stoich or leaner than stoich, they can't tell by how much.
Received 1,762 Likes
It is just finding that point on any motor set up and each motor is diff due to what every. Robert
I assume then during a WOT 30 to 90 MPH pull in 2nd gear AFR wouldn't change what I am seeing with this tuner, its not reading actual AFR. If its just reading the commanded AFR, wouldn't the commanded AFR change eventually at WOT?
St. Jude Donor '15
Commanded AFR should have changed @ WOT, yes. I can't say why it didn't without seeing the tune and a log.
But yeah, just using a hand held with no wideband you aren't seeing actual AFR, just commanded.
BJ67 (09-25-2016)
St. Jude Donor '15
Nice write up on what the DI motor does. Also like he is telling you here the leaner it can run to a safe point in any motor with out getting knock is going to make the most power.
He maybe reading actual, but with no input into the diablo, it will just display a constant unchanged valued. You need the analog input hooked to a wideband to read AFR.
BJ67 (09-25-2016)
I do have a choice of analog or digital log data, what would you set it to read?
St. Jude Donor '15
I suspect it doesn't matter--I think that is for logging external sensors, i.e. wideband, which it sounds like you don't have
I don't use an intune for tuning personally so I am not 100% sure.
BJ67 (09-25-2016)
St. Jude Donor '15
Could be frequency, could be airflow. Probably airflow. Does it have a unit on the MAF reading? Grams/sec, hz, lbs/hour, something like that?
St. Jude Donor '15
Then there ya go
You don't have a wideband, so reading AFR doesn't mean anything. Might as well stare at the sun and guess your AFR.
Command doesn't help either.
BJ67 (09-25-2016)
Just did a WOT quick data log with the Diablo intune, as soon as I got 99.8 % throttle, the equivalence ratio (AFR in parenthesis) goes from the steady 14.75 to 17.1 the whole time 2300 rpm to 6325 rpm WOT in 2nd gear. As soon as I lifted, goes right back to 14.75 . How can the commanded AFR be that lean? or am I interpreting it wrong.
