I joined the AFM relearn failure club
Dealer replaced my AFM valves due to CEL. They have had my car for nearly two weeks trying to get the AFM valves to relearn.
Stock tune and they have replaced the CCM and it still didn't help. I do have a Borla S type NPP cat back.
Two questions. Any suggestions on how to get the relearn to complete? My understanding is that it's a 2 minute procedure. I don't get it...New CCM and new valves.
What are the issues with driving the car if they don't 'relearn'? Tech said there is no CEL now. Do they just constantly open and close?
I just don't know what happens if they don't relearn. Dealer is getting GM involved now. I'm guessing they will say aftermarket catback, so they won't have to deal with it. Then, what issues will I have to deal with especially that they said the CEL is gone.
I've did some extensive testing with the afm and npp valves as of lately. I'm confident these do not need a relearn. If both of you and the other guy are having issues with aftermarket exhaust, I would lean towards the spring is having issues in the aftermarket exhaust
Here is something from another thread that might be applicable to your problem.
I have the borla atak exhaust. When I installed the system it was throwing a cel. I called borla and they sent me a new set of pipes "before the mufflers ". The code went away upon installing the new pipes. I guess the travel of the exhaust valve was not in the oem spec? So if i just disconnected the afm motors from the pipes but kept them wired, the cel would have disappeared. correct?
Call Borla, and have them send you new left and right pipes. I had my car at the dealer several times when I put the Borla NPP exhaust on, because I kept on throwing a code. The remedy was new pipes from Borla. I installed the new pipes and the codes went away
Great advice! Borla is sending me new pipes this week. Bummer the bumper and mufflers have to come out just to replace the over the axle pipes. Do you recall what codes your were getting before you installed the new pipes? That would really be helpful. Thanks!
Sr.Random input generator
Do the Borla pipes have flaps inside then, or do they just have a spring to satisfy the AFM system?
Borla recommended I try with flaps first (newer version than I have now). They do have pipes with simulators only. Apparently, with superchargers, they recommend simulators only. Borla rep believes u can slide the pipes out without removing the entire cat back and bumper. I'm haven't looked at it close enough, but dealer tech said the opposite.
Supporting Vendor
Received 1,012 Likes
You have to remove the bumper and cat back.
Without a doubt, the bumper will need to come off.
Is Borla now making a pipe with no valves ?
The reason I ask is that I can hear the valves going from v4 to v8 mode. They make a slight metallic "clink" sound.
I would think the AFM simulator with the actuator installed on the exhaust pipe could still overheat in track conditions and fail. It would be better to relocate the actuator and simulator away from the exhaust if possible.
I will have the new Borla over the axle pipes tomorrow, so hopefully AFMs will relearn after install. I'm curious if this fixes the CELs of P12F1 and P12FE.
Any new location will trigger the CEL. That's why some of the guy who cut out the valves with straight pipes put the electronics in the same location for the CCM check during startup for the AFMs to not throw a CEL.
People will say their aftermarket cat back system will not cause CEL, but once you have the AFMs fail, good luck with the relearn. I drove 1k+ miles with no CEL until failed AFM actuators threw codes. Grrr!
