K&N Air Filter - Oil or Not
Old 10-18-2016, 09:45 AM
cumbercr
cumbercr's Avatar
Default K&N Air Filter - Oil or Not
I'm installing a K&N filter and I'm just not sure whether to install it dry or with the K&N oil. I've heard the oil can damage the mass air flow sensor. Any opinions?
Old 10-18-2016, 09:52 AM
juanvaldez
juanvaldez's Avatar
I think they come oiled. The K&N filter only works if it is oiled. Over oiling is the problem.
Old 10-18-2016, 10:07 AM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
To much of the oil is not good.
Old 10-20-2016, 12:09 PM
only9balls
only9balls's Avatar
Don't run those filters without oil, they will not filter effectively. The filter elements are very high flow, and require the oil to capture particles, if you leave the oil off of it, it will let very large particles through. Just be careful not to over-oil it, it doesn't take much, and your MAF sensor should be ok.
Old 10-20-2016, 12:10 PM
Kracka
Kracka's Avatar
Received 5,675 Likes on 2,897 Posts
If you want a dry high-flow filter, check out Airaid and AFE. I've been using AFE's Pro Dry S for years with great results on various cars.
Old 10-22-2016, 03:09 PM
3 Z06ZR1
3 Z06ZR1's Avatar
Just oil it been using them for 40 years. No issues just don't soak it
with oil. You will be fine never had a sensor issue.
To K&N Air Filter - Oil or Not
Quick Reply: K&N Air Filter - Oil or Not
