How whould you fully convert an LT1 into an LT4?
vettefordays (11-01-2019)
You are way better off just throwing an ECS or A&A blower on your LT1. You'll make more power then an LT4, way less heat issues (intake temp/heat soak wise) and likely end up with a faster car over all. You'll make more power with less boost, best of all, it's the easiest/cheapest route. The LT1 is a great engine, it has more compression and more cam then an LT4 and the internals are still plenty strong to hold 700rwhp+
To answer your question (I haven't read all of the responses), the LT4 differed from the LT1 with forged pistons, slightly different rods, forged crank, the heads are cast from different aluminum for more heat resistence, cam, fuel pump and injectors.
The problem with building an NA monster is that it's the exact opposite of the LT4. It was meant for lower compression and boost. You will be redoing work if you do it in stages. Like LS3 guys turning their engines I to an LSA, if you get the parts for cheap than it may be worth it. However, at retail prices there are much better aftermarket equivalents.
I would also throw out looking into a Callaway kit. It's warrantied, has resale value and will match the Z06 in output if not exceed.
Yeah im pretty set on n/a.... so i wouldnt be able to slap on a supercharger down the road on the same parts?
Cruise-In IV Veteran
Honestly if it were me I would scrap the forced induction route and go for all motor. The grand sport was put in play to get around the heat and reliability issues C7Zs have when tracked hard. I would keep the car true to form just take it up 150+ hp...heads/cam/injectors/long tubes/intake/tune will put you there, sound bad azz, reliable as hell, and zero heat soak issues. 600+ crank will make that car absolutely fun as hell to drive. Going LT4 (you aren't making an lt4 as people said they are two different engines) route is complex lots of parts and going with forged internals is $$. If you go with long tubes, a nice set of heads, and aggressive cam its going be strong as hell and sound amazing. And save you a lot of money and less headaches. Good luck.
Received 1,296 Likes
2018 C7 of Year Finalist
I haven't had time to install my Lt4 blower on my stingray
but when I do I'll let you's no how it goes but 2 3 guys say it's good so far and powerful down the road gonna change the pistons
Go Canes!
I appreciate the complete post... i dont have buyers remorse because i dont want a 16' z06 and wasnt planning on waiting to find a 17' z06 for under $70k. I like the performance of the grand sport, enough to buy one and i love the idea of 600hp(crank) all motor (i guess this is a fantasy according to you) i was just wondering how difficult it would be to convert it over to an lt4, i was under the impression they were very similar engines minus a few parts. If its that complicated obviously your right, i'd prolly be better off just selling the lt1 and buying an lt4. My original plan was to squeeze as much juice as possible from the lt1 all motor and buy an lt4 if it blows.
Anyways i really do want that n/a build but i really do like the lt4. Just wanted to know what my options are, idk why ppl on this forum gotta spazz like its the end of the world. Sheesh, like i said read the title, if you dont agree, big whoop deal with it, why would you post your bullshit and waste everyones time your not saving anyone, im not a retard.
Like stated the point of this thread was to figure out how differant the two engines really are, part for part... a lot of you guys are pretty high strung. The thing i hate more than anything is when ppl start tellin me certain **** is a waste of money, dont worry about my money just worry about what i asked you, smh.... you corvette guys get hurt feelings quick. Theres a differance between asking for opinions and asking for facts.
By the way, you are the one being overly sensitive here. When you spend as much time as these guys do here, you tend to learn that what you are asking is bizarre. you cannot "convert" an LT1 to an LT4. That's like saying I want to convert my Camaro to a Corvette or turn your cat to a dog. Which is why all the answers are the same.
As we all said... if your goal is 600 (you said crank I assume rwhp), put an edelbrocck eforce stage 2 and headers. You will be there easily. And have the stock look that I think you are looking for.
torchred96 (01-12-2022)
Awesome good to know, i had no idea the lt1 can handle up to 700whp in stock form, awesome.
I like the idea of all motor cuz its more reliable. And with 500whp i think it would be plenty fast enough, i dont want a drag build. I want a balanced car i can rip on all day and take to autocross and track days. I really want that knarly n/a racecar sound.
Get a nice head and cam package, MSD Atomic intake, 102TB, 1 7/8"x3" headers & 3" x pipe. Get it tuned by someone who is good on LT1 tuning....Possibly even look into doing Flex Fuel for E85 if you want to get real crazy. I bet you can make 550 rwhp on the stock LT1 short block... It would be killer on the track and faster then stock Z06s on the street.
#33
Then definitely go NA...
Also i been hearing ppl get better numbers with 2"x3" headers.
#34
#35
I was at 550rwhp NA without the MSD intake and 102TB prior to recently going forced induction. Like the OP, I thought I wanted to stay NA and wanted the sound of the cam, etc. but the power after awhile simply wasn't enough. The entire setup remained the same when I recently slapped a supercharger and meth on it and the car is now 750+rwhp and will climb even further once I add forged pistons, fueling, etc etc etc. I also still have the stock LT1 injectors and HPFP and continue to run E85.
#36
Been running E85 since I was bolt-ons and still currently run it. The ethanol concentration isn't as important now for detonation purposes now that I'm running meth though. They actually pulled a ton of timing after adding the meth and supercharger.
#37
I'm Batman..
Pro Mechanic
Ant
#38
OP, you have just received the best advice available from both Higgs and Fyreant.
As for myself, I would do forged rods and pistons, with aftermarket 2.3l blower. Forget the lt4 other than the parts you will need to keep it fueled (inj, hpfp, etc).
John
John
#40
Any way you slice it you'll spend $10-20K to get 550-580whp
1. Trade in GS for Z06=17-22K, get 60 for GS spend 77 for Z06+Tax
If you can swap for USED Z06 would be cheaper than new, but you still have tax.....so $10K if find Used for $65K.
2. Lingenfelter 416=17K with 3 year warranty
3. TSP 416=13K, 10K for Engine and 3K installed and tuned
3. Katech=24K, 600whp
4. ECS or A&A = $9-10k with blower and Meth installed. Least expensive and most flexible option. And you have Z06 power without Z06 weakness. And can always reverse.
