Seat memory problem
Seat memory problem
ok so my seat won't go back to the set seat position when car is started. It will complete easy exit on shut off however sometimes when I enter car and start it the seat and wheel will not go to the set position. So I hold in the button on the setting I had and it just moves a tiny bit. If I hold it nothing happened but if I keep hitting it every time I do it moves a tiny bit until after like 15 pushes it goes to the set position. What is this? Anyone else have this issue? How was it fixed if it was? Thank you it is driving me crazy.
You may have the easy exit set to go all the way back and when it does that there is a button or something that it hits back there that wont let it do the presets when you get in. Try adjusting the exit position forward just a tad and then set it and see if that works.
My 2016 Zo6 operates the same way. When I get in the car, I have to move the seat slightly forward using the seat control on the side of the seat. After the seat moves forward, push the seat memory button and all the stored settings will be implemented. My dealer checked the seat and told me it is working as designed. He stated this is a safety feature.
This is what I do.
You also are supposed to set the 3 positions with the Memory Seat setting on Off in the Settings menu. Then after they are set you can go back to the settings menu and turn them on. I did both at the same time. Set them with Settings Off and moved the exit position up an inch, so don't know if it took both to make it work or just the seat up.
There is a good video on You Tube.
I experienced the same issue. I learned that mine was caused by the seat making contact (interference) during the "easy exit" seat movement (towards the rear) with my 6-point shoulder harnesses that I previously stored hanging from the harness bar, dangling behind the seats.
Possibly you have something behind your seat that is preventing the seat from moving into the full "easy exit" position. When the full "easy exit" position isn't achieved, the automatic seat repositioning out of the "easy exit" position is prevented.
I hope this helps!
Joe
