Which catch can with Z51/ E force?
ill be installing a stage 2 Edelbrock E force next weekend. I've been reading up on all the catch can threads and still haven't found this information. I see some catch cans have check valves others don't( I've read they are needed for centrifical blowers but PD blowers?) Some have one exit others have two. So I'm looking for a dirty side catch can for my application and if I need check valves and one or two exits? Any brands, part numbers or links would be great! I'm hoping to stay under $200 if possible..Thanks
Are you a wet sump or dry sump??
my setup is a wet sump, I have the line from each valvecover to the induction (like factory). From the valley I run a line to a RX catchcan then the out line to the blower snout with a check valve facing the inlet (don't want to boost the crankcase when the blower pressurizes)
Thanks, I ordered the Elite E2 with the two exit outlets and one line into the can. I'm routing the line from the crank case to the in of that catch can. Then one of the exits to the manifold (PD supercharger) the other exit I'll be tapping into the coupler between the air intake and throttle body. Those will also get check valves.
The valley is the biggest source of oil over the valvecovers in my opinion...
David is a smart guy, just trying to understand how you routed your setup
thats a good setup, but do you have anything between the valley and blower inlet??? If not I would have a catchcan setup to catch oil there otherwise you're going to coat the inlet of the blower with oil...
heres a pic of how its setup right now. Valley capped, intake manifold with a T for the bov and the line from the pcv valve on the can. It didn't make sense at first but it's creating a vacuum now and the oil smell is gone.
I just capped it for now since I didn't have the extra lines to connect it all, but even with that, I'm not sure if that's how the can is designed to work. Its creating vacuum so I can assume its working
Supporting Vendor
my setups and instructions are specific to my products because they have function that others do not. you cannot compare apples to oranges.
any questions my email is always open mightymousesolutions@gmail.com
I sold a system this morning to a guy with an elite kit who was blowing the dipstick out due to only stock breathing capability on a highly modified build.
be very careful routing blowby around and blocking this and that with check valves. it is only increasing crankcase pressure vs. setting it free.
__________________
Solutions for the common gearhead #made in USA
mightymousesolutions.com
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
#mmsolutions
eric03l (11-30-2016)
