Best CAGS Skip Shift Eliminator for 2017 GS?
Received 1,694 Likes
St. Jude Donor '15
^^ Yeah, just get the cheapest one, they're all the same.
iI just installed mine today, and checked the oil level of the diff.....it was 4 ounces low...not bad compsred to the 15 to 20 ounces of factory underfill that others have found.
That's where I got mine....FleaBay..for $12......and also got my Tops Down Tech Window Controller $131.
There's really not a lot of difference between any of them, like others have said. I bought mine from Summit Racing through the Internet. Although many have said I wasted my money (anyone married will laugh at that one, a blown $20 is nothing!), I really like this modification....short shift all over the place with no nannies!
Is there a "blown fuse" that can be installed on C7's like what was done on C6's that did the same thing as the CAGS eliminator?
Also, if not, where is the CAGS eliminator plugged in on the C7?
The CAGS eliminator plugs in to the harness that gets disconnected from the skip-shift solenoid, located on the transmission. There is no fuse you can pull to eliminate CAGS on the C7.
