JRZ C7 Double Adjustable Coilovers
Former Vendor
St. Jude Donor '13
These gunmetal Forgeline 18" GS1R wheels are looking phenomenal sitting on a JRZ RS Pro Susension, a Brembo GT big brake kit and Hoosier R7 tires!
Former Vendor
St. Jude Donor '13
When you decide to become serious about how your car handles!!!!
Recommended applications
• Highly modified Street/DE
• Experienced club racing
• Entry level professional racing
JRZ RS PRO SPORT
Double Adjustable - External Reservoir
Adjustable compression damping 14 clicks
Adjustable rebound damping 24 clicks
Every click noticeable change
Ride height adjustable
Gas pressure adjustable (nitrogen)
Uses spherical bearings
Valved for more chassis control and performance
Remote reservoir
Mag Ride Eliminators
http://www.xplosiveperformance.com/C...rs_p_4119.html
JRZ RS PRO SPORT
Remote reservoir
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
JRZ RS PRO SPORT
Remote reservoir
JRZ RS PRO SPORT
Remote reservoir
Former Vendor
St. Jude Donor '13
JRZ RS PRO SPORT
Remote reservoir
Remote reservoir
Former Vendor
St. Jude Donor '13
The JRZ RS Pro is shipped as a bolt on kit with installation instructions and always comes with our world renowned personal service of JRZ.
Benefits
• Better chassis control for higher rate springs/power/ratio
• Street ride, racing performance
• Easy to change configurations
JRZ RS PRO SPORT
Remote reservoir
Benefits
JRZ RS PRO SPORT
Remote reservoir
Former Vendor
St. Jude Donor '13
JRZ RS PRO SPORT
Remote reservoir
JRZ RS PRO SPORT
Remote reservoir
Former Vendor
St. Jude Donor '13
JRZ Suspension Engineering offers the best high performance club sport damper available today. Combining the best aspects of our JRZ RS and 2-way racing damper, the JRZ RS Pro gives the owner ultimate suspension tuning ability while maintaining compliance for driving on public roads. A mono tube double adjustable damper with adjustable gas pressure, the JRZ RS Pro offers an increased adjustment range allowing the user to tune the car to their further needs. The JRZ RS Pro is available as a complete kit with springs and mounting hardware.
Taking club sport performance to the next level, the RS Pro has a remote canister with a digressive blow off system. Digressive blow off allows for a stiff compression valving while maintaining smooth response.
The result is a damper that provides ultra solid platform with smooth bump compliance. JRZ standard 22mm piston rods maximize flow to the blow off valve response to great chassis control without using a high spring rate.
The design of the JRZ RS Pro takes you to the next level. Stiffer cars with higher levels of power demand the control JRZ can supply.
With the control of gas pressure charge as well and compression and rebound adjustments, the JRZ RS Pro will get the most out of your high performance car.
Benefits
Benefits
Former Vendor
St. Jude Donor '13
Benefits
JRZ RS PRO SPORT
Remote reservoir
Benefits
JRZ RS PRO SPORT
Remote reservoir
#34
Former Vendor
St. Jude Donor '13
#35
Former Vendor
St. Jude Donor '13
JRZ RS PRO SPORT
Remote reservoir
JRZ RS PRO SPORT
Remote reservoir
#36
Why exactly do you have dual springs?
I've seen that for cars with a ****-ton of downforce, effectively creating low and high speed (street and track) spring rates, but I don't understand why you'd want dual springs otherwise. That can't be fun to drive.
I've also been drinking heavily.
#37
Former Vendor
St. Jude Donor '13
JRZ RS PRO SPORT
Remote reservoir
Remote reservoir
#38
Former Vendor
St. Jude Donor '13
#39
Former Vendor
St. Jude Donor '13
#40
Former Vendor
St. Jude Donor '13
