Splicing baro sensor
anyone know of this? Supercharger c7 baro keeps climbing under boost. I heard there was something you can do to trick it
I just had my C7 ECS supercharger installed and got codes for the baro so had the tuner just turn them off so they wont show. Is this what you are wanting to do?
Received 2,379 Likes
As mentioned, there are parts available to do it right and they take about 90 seconds to install. Why shortcut that?
thanks everyone, wound on getting the brrwkout kit for dsteck
I had got the p2227, 2229 and 2230 codes. ECS said to just tune them out. Are these codes the kind you can tune out? Can you explain the iat breakout thing more, Im not sure what that is? Thanks.
This is not really needed unless you are boosted and/or running meth. The Baro sensor sees boost with a Centri and screws up the Pressure Ratio readings so you want to pull it out of the intake tube and the IAT sensor gets moved so you can let it see the temp change of meth without spraying through the MAF.
