Stabilitrack warning on my C7
I was out for a cruise last night when my engine light starts blinking and I get Stabilitrack warning. I heard and felt nothing different in the car, it just came on randomly. Is Stabilitrack the rear torque vectoring differential motor?
Either way it is going in to the dealer next week, this is the first problem I have had with my C7.
St. Jude Donor '08
Received 8,919 Likes
If you have a CEL and Service Stabilitrack or TC message that means there is an engine problem causing an issue with those two features.
Active Handling (Stabiltrack) depends on the ECM to reduce engine torque when requested by the EBCM. If the ECM detects an engine control issue that will prevent it from responding correctly to the EBCM request it will send a signal to the EBCM that it can't respond. Once that happens the CEL is displayed and the EBCM sets a code that displays the Service Stabilitrack message. Once the cause of the Check engine light is resolved the Stabilitrack message will go away (sometimes it has just been a loose spark plug wire). In the C5 and C6 the EBCM code that caused the service message basically meant the problem isn't here go look at the ECM and engine. I suspect the same thing happens in the C7.
Bill
The following 2 users liked this post by Bill Dearborn:
leadville1 (01-13-2017),
Mamandoli (01-23-2017)
Check to make sure the plug wire is seated properly on the plug. The boot may be over the plug but the end of the wire that clips onto the head of the plug may not be making a solid contact with the plug.
Bill
Bill
leadville1 (01-14-2017)
Problem came back, it turned out I had a broken valve spring on my Texas Speed Head and Cam kit. They are replacing it today, strange failure, unprecedented according to Texas Speed.
