High pressure fuel leak
Five weeks. That's how long my 2015 C7 has been in the Toyoda dealership. That's right, Hilo Hawaii does not have a real Chevy dealer. The car smelled of raw gas when I drove home. Being a mechanic I thought it might be a leaking injector. Lucky for me they do sell Camaro's which use LT1 engines. Long story short. new injector, manifold and O rings. Still leaks. Now they tell me the entire fuel line needs replacement. Which requires removing the transaxle system, exhaust and other parts. This will take three days of work or more. Has anyone else had this problem ? I read that one of the C7R race cars had a fire from a fuel leak down in Florida last week. Hope this will not be a common event.
Received 1,298 Likes
Are you sure it is a high pressure leak? There is a known issue of fuel vapor leaks that may be easy to rule out:
http://www.corvetteactioncenter.com/...eaks-1312.html
I didn't realize Hilo didn't have a Chevy dealer. The Kona dealer closed several years back. I'm a Kona resident one week a year.
Ron
Ron
Ron
Ron
Must be nice to live in paradise? Small price to pay to not have a Chevy dealer.
A lot of folks, including me, had that raw gas smell after the gas tank is overfilled. When the fuel pump clicks, don't top it off at all. No more smell - ever. But perhaps you already knew this. Just mentioning just in case...
The intake was removed then you could see the leaking gas line. Once that was repaired it started to leak under the car. The dealer replaced ever thing but the supply line going from the tank to the engine. This included, the injectors, all o rings plus the manifold and the tank fuel pump. As you know the fuel pressure is over 3000 PSI. These parts are one use only. If taken apart they have to be replaced. [compression fittings]
Received 2,379 Likes
just so you know it's about 2100 psi at WOT and at idle its around 350-375psi
Update: I had my Chevy truck in for service and was talking to the service manager about my C7. I thanked them again for helping to get the fuel system repaired. He said that GM refused to pay the $5000 for warranty work. Basted on the fact they were not a Corvette dealer. The car is not under warranty now ,but there not to interested in doing any more work on my C7.
My 19 GS with 1400 miles on it has been in the dealers shop for 2 weeks now. This whole time waiting on a fuel module. It has the strong gas smell near the drivers side rear. Dealer says no idea when the part will be in.
What the hell GM? Cant even keep basic parts in for new cars? In all my years of car buying and repairs ive never seen anyone so unable to ship parts promptly.
T
