Increased wheel and tire size search
Have checked other posts and been searching online for hours.
Does anyone know a site or resource where I can find larger wheels that will fit my 2015 Z51? This would be for a dedicated track set.
I wan't to buy Toyo R888Rs. (Not R888s)
If I want to stay with 19" front and 20" rear I would need-
For a 305/30/19 front a 19" x 10.5" - 11.5" rim, and for a 315/30 rear I would need a 20" 20 x 10.5" - 11.5" rim.
If I want to downsize to a 18" front and 19" rear I would need-
For a 295/30/18 front an 18" x 10.0" - 11.0" rim, and for a rear, a 305/30/19 with a 19" x 10.5" - 11.5" rim.
These wheel size requirements for these tires are right off the Toyo website.
I verified on tiresizes.com (hopefully) that these size tires are an acceptable alternate to OEM tires and will not rub.
Offset would have to be close to the OEMs of 56mm front and 79mm rear, and bolt patterns would have to be 5 x 120.65 as per OEM numbers.
I'm assuming I could go to a larger offset, but at some point the tires are going to stick out past the fenders too much?
How would I know for sure if these size wheels will fit (clear the calipers) and these size tires will fit. (Won't rub.)
I saw on a 2015 post that someone used Toyo R888s on stock rims, but I show on the Toyo website that the stock rims are 1/2" to narrow, so I don't know how he got away with that.
Thanks!!
Thanks!!
Received 8,917 Likes
Why don't you try calling CCW and asking what size and offset they recommend?
http://www.weldwheels.com/ccwheel/
Bill
Bill
Thanks!!
Thanks!!
