New From RPI Designs!! C7 Corvette LED Rear Fascia Lighting Kit
Platinum Supporting Vendor
Introducing our new C7 Corvette rear fascia led lighting kit designed specifically for the C7 Corvette Stingray. This kit is pre-wired to tap into the rear side markers so they will come on when the marker or headlights are on. They can also be wired into our C7 Corvette fender cove and hood scoop kit if you want to control them wirelessly. Purchase our under car wiring kit if you want to wire them to the cove lighting kit. This is a great option for car shows or cruise in's. This kit will illuminate the vents on each side of the taillights and the vents on the lower rear fascia and also includes a exhaust area lighting kit. Select from our many colors of White, Red, Green, Yellow, Blue, Orange and Amber, but RED or Yellow/Amber may be the only legal colors. Check the laws in your state. If you want to use other colors we recommend using our fender cove remote controlled kits to run this kit so you can turn them on or off when wanted.
This kit includes:
(2) waterproof led strips per side with a total of 54 superbright leds.
(1) exhaust led kit with 24 bright waterproof leds.
Mounting hardware and Instructions
Item # C7-rfsb-5 Use coupon code RPIDON5 on line or phone during check out and receive 5% off the listed website price !!
Website Link: http://www.rpidesigns.com/shop/item.aspx?itemid=3319
This kit includes:
__________________
