2014 2015 C7 Corvette Stingray DBA 4000 Brake Rotors @ RPI Designs
Platinum Supporting Vendor
4000 Series DBA Rotors For the Corvette C7 Corvette
There will come a time when you will need new brakes for your C7 Corvette, some quicker than others. We suggest the DBA 4000 Series is an excellent mid series street legal brake rotors for your Corvette C7 that is an excellent upgrade from the OEM Rotors. The DBA 4000 Series Rotors that we offer are an exact match for OEM equipment for the Corvette and can easily be installed without any additional components or modifications to your Corvette.
DBA’s 4000-series enhanced performance rotor features Thermal Stability Profiling for improved heat handling. This unique process provides greater thermal stability than standard street discs. TSP enhances the microstructure of the disc rotor for performance applications. Greater thermal stability allows your discs to take more heat, making them more stable under heavy braking for longer. TSP also means improved brake pad and disc rotor life, and delayed brake fade.
Also unique to DBA Rotors, Thermo-Graphic paint markings are used for effective heat monitoring which change colour at specific temperature thresholds. By monitoring the markings, drivers can check their braking performance quickly and easily.
4000 Series DBA rotors are availabe in slotted or slotted and drilled configurations (XS), The unique 6x6 Wiper Slot is designed to efficiently clear the gases, dust and debris, resulting in a cleaner disc surface for better braking while maintaining maximum friction.
4000 series rotors also incorporate the innovative Kangaroo Paw ventilation design, which runs cooler, stronger and outperforms traditional straight vane disc rotors by up to 20%.
Designed for the performance street and motorsport enthusiast.
Sold in pairs or a complete set of front and rear, the DBA 4000 Series Rotors are an excellent brake upgrade for your Corvette. For an even higher performance braking package, use the DBA 4000 Series rotors on the rear and DBA 5000 Series for the Front.
Slotted only comes with a Black Hat. Slotted and drilled only comes with a Gold Hat.
Please note, there are several options to choose from depending on vehicle option and brake rotor option. please make correct selection when making your purchase.
Item # 4276 - ND
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5296
Item # 4276 - ND
__________________
