What is 7th digit on vin from right
Regular production Z06 vins end with F56xxxxx
.corrected
.corrected
Cruise-In VI Veteran
Cruise-In VII Veteran
2015 VIN Decoding:
This is an example of a VIN # for a 2015 Corvette Coupe (3LT, Z51, MN7):
1 G 1 Y L 2 D 7 X F 5 1 0 0 0 0 1
There are 17 characters. Starting with first character on left the codes are:
01. "1"= Built in US
02. "G"= General Motors
03. "1"= Chevrolet
04. Denotes the car line: Corvette is a "Y" body.
05. Provides more info about the car:
.. A=1LT M/T
.. B=1LT A/T
.. C=2LT M/T
.. D=2LT A/T
.. E=3LT M/T
.. F=3LT A/T
.. G=Z51 1LT M/T
.. H=Z51 1LT A/T
.. J=Z51 2LT M/T
.. K=Z51 2LT A/T
.. L=Z51 3LT M/T
.. M=Z51 3LT A/T
.. N=Z06 1LZ M/T
.. P=Z06 1LZ A/T
.. R=Z06 2LZ M/T
.. S=Z06 2LZ A/T
.. T=Z06 3LZ M/T
.. U=Z06 3LZ A/T
.. 9=export (Non US, Non Canada)
06. Body style: "2" = Coupe, "3" = Convertible
07. Restraint code: D – AJ7 Active Manual Belts, Airbags – Driver & Passenger and Seat Side
08. Engine: LT1 = "7", LT4 = "6"
09. Check Digit – 0 to 9 or X
10. Model year: F (2015)
11. Plant: Bowling Green = "5"
12-17. Production sequence number that starts with the #100001 for each model yr. Z06s will start with #600001
The above explains each digit of he VIN. The F is for year 2015.
03. "1"= Chevrolet
.. A=1LT M/T
.. B=1LT A/T
.. C=2LT M/T
.. D=2LT A/T
.. E=3LT M/T
.. F=3LT A/T
.. G=Z51 1LT M/T
.. H=Z51 1LT A/T
.. J=Z51 2LT M/T
.. K=Z51 2LT A/T
.. L=Z51 3LT M/T
.. M=Z51 3LT A/T
.. N=Z06 1LZ M/T
.. P=Z06 1LZ A/T
.. R=Z06 2LZ M/T
.. S=Z06 2LZ A/T
.. T=Z06 3LZ M/T
.. U=Z06 3LZ A/T
Harbgrogan (12-01-2020)
2015 VIN Decoding: This is an example of a VIN # for a 2015 Corvette Coupe (3LT, Z51, MN7): 1 G 1 Y L 2 D 7 X F 5 1 0 0 0 0 1 There are 17 characters. Starting with first character on left the codes are: 01. "1"= Built in US 02. "G"= General Motors 03. "1"= Chevrolet 04. Denotes the car line: Corvette is a "Y" body. 05. Provides more info about the car: .. A=1LT M/T .. B=1LT A/T .. C=2LT M/T .. D=2LT A/T .. E=3LT M/T .. F=3LT A/T .. G=Z51 1LT M/T .. H=Z51 1LT A/T .. J=Z51 2LT M/T .. K=Z51 2LT A/T .. L=Z51 3LT M/T .. M=Z51 3LT A/T .. N=Z06 1LZ M/T .. P=Z06 1LZ A/T .. R=Z06 2LZ M/T .. S=Z06 2LZ A/T .. T=Z06 3LZ M/T .. U=Z06 3LZ A/T .. 9=export (Non US, Non Canada) 06. Body style: "2" = Coupe, "3" = Convertible 07. Restraint code: D AJ7 Active Manual Belts, Airbags Driver & Passenger and Seat Side 08. Engine: LT1 = "7", LT4 = "6" 09. Check Digit 0 to 9 or X 10. Model year: F (2015) 11. Plant: Bowling Green = "5" 12-17. Production sequence number that starts with the #100001 for each model yr. Z06s will start with #600001 The above explains each digit of he VIN. The F is for year 2015.
wow is this a record?
