Order a 2015 ECU while you can!
Will be doing some tuning on buds new Z. Rather no use his ....
Betcha GM start installing some sort of tamper film on ECU/connectors?
I honestly don't believe having a separate ECU will do anything to help you keep your warranty. If your car blows up on the track or anyplace else and you put the stock one back, there is no data to contribute to the problem, so GM will void your warranty because I would imagine they are smart enough to figure this out. If I am missing something, please enlighten me, but when I considered this with my 2008 Z06 each tuner that I mentioned this to, gave very vague answers regarding this being a loophole. My sense was they know it will be easy for GM to build a case against you if you replace the ECU, have a problem and then put back the original one.
Doesn't take a rocket scientist or a computer hacker to connect those dots...
So are you saying that if you pop a head gasket or bend a rod or etc... that there is a code for that? Do you have any tuning experience?
I get what your trying to say....there would be evidence of a misfire code. Just because there would be no misfire codes is not conclusive enough to say whether the ecu was swapped. Seen plenty of rods tossed threw blow and no codes were saved.
There will be NO codes...NO DATA (engine temps, RPM's, throttle position, etc.), zip, nothing, NADA...when you plug that new ECU in, there is nothing stored in it.
Sure...IF the engine will run you could get something stored into the memory, but in the case of catastrophic engine failure you are screwed.
My C4 ECU stores the last 5 minutes of running...I'm sure the new ECU's store MUCH more than that.
P.S. And do you think that OnStar system is only for your emergencies? When time stamps in the codes don't match up...they start digging deeper. And they hide stuff in places ALL OVER the car...in different (unrelated) modules.
And, last but not least, what you want to do is considered FRAUD. I'm sure GM lawyers would love to get their hands on that information...
Bottom line - tamper and be prepared to fight but it's you against GM - a huge Corp. Will you win?? you'll go broke trying though
It astounds me how many will go through such steps to defraud a company. What you are proposing is illegal.
Want to tweak the ECU? Know the risks and play the game.
Want full warranty? Stock is the way to go.
So if there is a power loss to the computer, it saves the data now? I know in my c6 and every other car I own, once I pull the battery cable, everything is gone.
It would seem to me that swapping the ECM and then saying that the battery as pulled at some point because you were installing something electrical would be a completely acceptable answer.
Received 2,379 Likes
I don't get it.....if you break your car then pay to fix it.
wtf is wrong with people today????
it's people that try and defraud that screw people over that has made if difficult for those with legitimate problems.
Those with modifications that have a legitimate issue NOT RELATED to the modifications get turned away because of someone trying to get a free repair/fix.
It's unfortunate that just because a car is modified a car manufacturer will claim the modifications cause the fault (even when it obviously did not).
Ding. If you want to mod your car from stock, that is great. BUT ACCEPT THE CONSEQUENCES for your action as it is NOT GM's responsibility any more.
And if you don't think that GM have some guys on staff tasked with scouring forums JUST LIKE THIS looking for this kind of ammunition, you are crazy.
1. VERY significant orange peel paint.
2.misaligned body panels.
3. An ECU that requires a warranty voiding tune.
4. Serious questions on whether this car can be run for more than 15 min @ greater than 70 degree temps. (distinctly different than #3.)
