Heat soak power loss
Nope!
There is something going on, Nspec and Nine ***** runs showed the Z06 getting pulled more and more as the runs went on. Some will say it is not heat soak but I don't buy it. My 03 SVT Cobra would do the same thing the more times you ran it back to back....it would slow down due the Eaton getting spun so hard and getting so hot.
I cannot recall anyone with proof that heat soak occurs. I am not denying that something may be going on, just that heat soak has not been proven to be the cause. Or even that there is correlation. It would be very helpful if we could gather some data that separates cause and effect.
Not sure if this qualifies as proof but this is from Vette Magazines recent test of the C7 Z06:
"Downside? The blower gets insanely hot and takes forever to cool down. Even after putting two bags of ice on top of it for 20 minutes, the supercharger was too hot touch. Heat soak is a serious hindrance to track performance. Combined with 85-degree temps and 70 percent humidity, we could not match GM’s dragstrip numbers, which were recorded on a prepped track on a 65-degree day."
http://www.superchevy.com/features/2...ng-boundaries/
Scraping the splitter.
Are you guys done being "clever"?
The Consigliere
Received 5,432 Likes
So how is it that Lawdogg got his best 0-60 pdr run on run #25 of 30 back to back runs?
One does not need to be very clever to recognize these facts.
BTW...what are the IAT2's?
S.
Let's forget this part too (or better yet, not even mention it ):
S.
Having gone 11.73 in a six-speed automatic-equipped Stingray at 118.86, we fully believe that car is capable of 10s on the stock tires.
Received 8,919 Likes
Short dyno runs, zippitty do dah runs on a highway and drag strip runs really don't prove anything. The car has to be run continuously hard for 15 to 20 minutes. Dyno pulls don't last much longer than a 12 second drag race so really don't let the engine get hot.
Bill
Bill
From the IATs floating around on this forum and what the tuners are saying, I'd say there is not a heatsoak issue. It seems there is overzealous pulling of timing from a lot of other factors adding up. It is basically an overly consertive ecu for emissions. A simple 160F thermostat will likely solve this. All this will do is turn the fans on sooner before the engine gets too hot. This higher temp thermostat, along with the relatively low oil viscosity were done to improve emissions just as has been done to other cars. All of these emissions regulations are starting to get crazy.
0-60 is almost entirely reliant on the launch. I doubt it will be affected much by timing pull. Especially if he was getting better and better at launching each time. It makes sense that the best pass would come near the end of his runs.
