Corvette C7 Z06/Z07 - Brake pads !
Hi all,
I'm owning a few Z07/ZR1 pads sets from my old C6 Z07 2013.
I'm now waiting for a C7 Z07 in the next months.
Are my "old" pads compatible with my new car ? (same sizes ?)
If yes, front and rear ?
Please answer only if you know !
(i've already the reference of the C7 Z07 pads)
Thanks in advance.
Best regards from Switzerland.
Mike
Thanks in advance.
Mike
Hi all,
Thanks in advance.
Mike
Thanks in advance.
Mike
Yes the bad are the same and will work BUT the sensor wire length is I believe shorter on the ZR1 pads. You will need to splice some more wire or make a small extension harness. Very easy to do.
This was discussed before but is buried in this section, so I will tell you what was found out:
