iPod interface freezes?
I just got my new Z06, and I love it - it is phenomenal. But I noticed on the very first day a glitch.
I have an iPod plugged into the USB port in the center armrest. Every time I start the car, whatever song was playing resumes playing, and the artist/title/artwork all display correctly. But when the NEXT song starts, the display does not update. I can drive and listen to as many songs as I like and the display never changes. If I shut off the car and start it again, it resets, and the current song data is displayed correctly, but again, it will never change to the next song.
Anyone else have this problem or know of a solution?
Thanks!
Thanks!
I'm sure you have already, but restart your iPod just in case.
The iPod / iPhone interface seems super glitchy to me. I have always had some kind of problem on all my GM cars when I use Apple stuff.
I'll just add another question to the mix too. I've got an iPhone 6 Plus plugged in (BTW- it's fits perfectly lying on top of the open cup rests- kind of cool!). When I hit the forward / back buttons either on the phone, the headunit or the steering wheel it takes about 3-4 seconds to move. Then it it usually freezes showing the info for the next song, but nothing plays. I have to press "pause" and "play" several times to get it to play. Anyone else experience anything like that?
I did update the software on the phone the other night to 8.1.3 and that seems to have fixed the issue I was having in the truck. haven't been in the Z since then to see if it had an effect there.
Thanks!
Thanks!
I had the same problem exact with an iPod Classic. Bought a new connector of higher quality and throughput and that didn't work. So my son suggested I buy an iPod Touch -- that solved it. However, two things I learned from the OnStar Infotainment tech (who was terrific): 1) Apple audio cannot be used with Bluetooth -- Apple did not make it compatible with MyLink, so you still need the USB connector; and 2) The USB connector behind the nav screen only charges devices -- cannot be used to transmit audio.
So 'todm' how do you connect via Bluetooth? Is that for audio or voice? Thanks.
Frank
Frank
Frank
Frank
'todm' -- thanks. I'll check with my dealer the next time I'm there. Thanks for noting 'both voice and audio.' Frank
I have the same problem with the ipod, the next song does not display on the screen. Mine is plugged into the usb behind the screen and it does transmit audio. All 3 usb's seem to have the same issue with the ipod though. Im gonna steal one of my kids Itouch's and see if that works.
Evan Q.
Evan Q.
I reset the iPod, and then reattached it to the car, restarted the car, and now it is working perfectly fine. I have no idea if that really fixed it or not. I suspect this is just some intermittent glitch.
Thanks for the replies; if the problem comes back I'll take it to the dealer (probably nothing they can do but report it to GM) and will post any new information I get.
