Took Delivery A8 Z06 San Diego-CRACKED TIRES!
#41
Harold may not have the best bedside manners but his premise is sound.
The buyer should be aware of what they are buying when they purchase a performance package which includes tires that barely meet the minimum DOT requirement for public road use. There are Z06 trims available that don't include this extreme tire so it's not like GM is forcing everyone to wear it. It's the same thing with the Trofeo R on the Z/28 and no one is blaming Pirelli for building performance tires that crack under load below a certain temp, because Z/28 owners know what they're getting into and those that live up North or want to daily drive simply swap out their tires for all season ones.
That said, this isn't really relevant to the thread, for the OP didn't take his car to North Dakota in his summer performance tires, it was delivered that way to him in SoCal. That is unacceptable on behalf of GM's part for it is their responsibility to get the vehicle to the owner without tire damage, be it structural or cosmetic.
#42
This warning has been out for GT500's since 2011, Camaro ZL1's since 2012. It's part of owning a car with extreme performance tires. Car has a warranty for a reason if you have problems.
#43
Let's put it this way, I've had three Corvettes including a C6 Z06, and none had tires that could not take sub zero temps. I've stored my Porsche in my non-heated garage now for three very cold winters and it's tires are still good to go.
I'll ask you this, did GM tell anyone that the tires had to be stored in a heated environment before they sold them their new C7 Z06?
#44
Alcoholics Unanimous
Received 1,642 Likes
St. Jude Donor '15-'16
The tires are cracking on base corvettes, and base Z06. If You move the car (Not necessarily drive it) when the is temperatures below 20°F (-7°C) the tires will crack, requiring you to replace them. You don't see this as a problem? And yes GM is forcing you to wear these tires, I didn't see any other tire option from the factory.
#45
Its an anti-GM comment by a person who owns a "partial German Gov't Motors" built car.. Go figure.
Point is that some will look for anything to bitch at GM about. This is a GM issue that can easily be sorted out with Michelin. That's what warranties are for.. and I don't think anyone owning a C7 or otherwise should stress out about this at all.
#46
It's class action "suit" and it was meant to be a joke. Last time I checked, suing someone for being stupid usually gets dismissed, because if they didn't, the courts would be backlogged for decades.
#47
#48
Will be interesting to see if the same tires crack on the GT3 RS. Maybe Porsche pays more for the same Michelin tire and gets better rubber.
#49
hey
they are tires not really meant for the cold. so if they give you new ones you will have the same problem next year on your own dime. Unless, you park it in a heated garage or put tires on meant for the cold temps.
they do the same with all the V8 Camaros.
So the zo7 option with the track type tires not only wear out quickly, they also will crack. just get use to it, its what you are buying, not GM doing it to you. Nice color combo, love the standard wheels the black wheels with black tires disappear in pictures.
#50
I wonder if heat cycling at the plant would help? My experience with the GY's is they won't crack in cold temps if driven at normal temps prior to that (if that makes sense). Just a thought.
#51
I do agree the base Z06 tired shouldnt be cracking under freezing temps, at all.
Those with cup tires complaining are barking up the wrong tree.
#52
My bad - I thought the OP tires were the cup tires. I retract my statements in respect to the base tires. I am 100% wrong there.
I went out and checked mine...no cracks
#53
Finished the prep on my car tonight including putting the stage 1 front splitter on, attaching the rear spoiler extension pieces, admiring the flat underside, and ending with a full wash.
Aside from having the cracked Super Sport tires, everything else fit and finish is nearly perfect. Orange peel is minimal and panel fitment is right on.
#54
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
Just saw my new Z07 for the first time last night and happy to report no cracks in the cup 2 tires. Body panel alignment very good, paint finish is just ok, black shows everything. It was delivered in the single digits and has 1 mile on it. I'm leaving it with the dealer for a few weeks and they understand DO NOT move it when temps below 30.
#55
This has been discussed a lot on the Stingray forum, must be a lot on the Z06 side who didn't read the posts.
Some points that came out:
The tires crack when they freeze, then are moved. If you store it in the cold you shouldn't get cracks, but if you get them cold (Below 20) and move the car you can.
The tires affected seem to be the Z51, Z06, and Z07 tires. The Base Stingray tires are not so soft. These are great tires, but if you can't live with the summer restriction you should swap them out for something else (the good news is that they sell well on the used market).
The cracks are reported to be cosmetic, so you should be able to drive your car until you get the new tires. I doubt anyone would trust them for high speed use or a track day though.
GM is treating the cracked tires as a shipping incident, not a warranty claim. Some believe this is why there are a lot of cars still sitting at the factory waiting to be delivered. My A8 Z06 was built on 1/26, and it still sits in Spring Hill TN. waiting for a truck. That's the overflow location they are using because the Bowling Green lot is full. Even so, the tires could have cracked when the moved the car from Bowling Green to Spring Hill (I hope not).
There is some talk that the cracks may not show up right away. This is of concern, since once you have the car you can be responsible for the cracks if you don't follow the freezin' rules. Michelin has outlined the restrictions well, and does not replace these as part of the tire warranty.
#56
Buyers must educate themselves. This is a very substantial purchase. I find it intriguing how many here are acting the way they are about a car designed for major track use.
#57
The OP lives in San Siego and while he may have understood what you were saying and intended using the tires in warm weather , how can anyone control the weather in Bowling Green ? The tires arrived in his warm destination with the tires already cracked.
#58
Os all the manufacturers one would think GM would be extra cautious about releasing a vehicle with a potential life threatening flaw.
So embarrassing that they are allowing their Flagship vehicle to be delivered like this. It's not like some deep mechanical tear down is needed to spot this.
#59
Harold, it is good that you retracted your statement but I think you are still missing the point.
The rally cry that the tires shouldn't crack, that they should be designed not to crack (Now, I am talking about the cup tires) is just preposterous.
#60
Don't agree with your statement as to a totally botched rollout. There is nothing wrong with the vast majority of Z06-Z07. I am perfectly satisfied with mine as are friends who own theirs. As to the tire issue mistakes were made with the A8's, but easily solved by accepting the new tires if needed and by taking out the tire warranty on leaving the dealership with your exceptional vehicle if you feels added security is needed!
