Fuse Box / Exhaust flaps fuse
Just wanted to double check with others to see if I pulled the correct fuse (#42 in fuse box in engine compartment) thanks in advance!
No need to pull fuses!
1. Home button;
2. Touch settings;
3. Touch Driving mode;
4. Touch engine sound mgt;
5. Vertical bar down to "track";
6. Touch Track for loudest mode.
Your Welcome!
1. Home button;
2. Touch settings;
Your Welcome!
Alcoholics Unanimous
Received 1,642 Likes
St. Jude Donor '15-'16
Yanked it, no difference than track. So I did this: https://www.corvetteforum.com/forums...me-instal.html which got me close but not quite there, so X pipe next week for punctuation.
Leeds.io
St. Jude Donor '14-'15-'16
Btw on my C6Z I ran a fuse switch to all the exterior lights other than the headlights. Talk about a true stealth mode.
Thank god they never caught up.
Leeds.io
Sup Gene.
I have mine set to track all the time as well, but I find that it still codes, goes quiet, sometimes. Not sure if there is an actual problem there or not. My seat memory does this as well, sometimes it won't go up. It still goes to exit, I'm fat, so it's an intermittent issue. I never had any problems with my GS, so it may just be new model ticks.
Sup Gene.
I've never heard of a cat-back exhaust voiding any element of a warranty if properly installed.
That's the AFM valves closing. You have the exhaust flapper valves that you can control through the software AND AFM valves which you cannot.
If Thomas has an M7, so far as I understand it the only time AFM is active is in Eco mode. It's just the nature of the LT4 to purr quietly in neutral once warmed up.
