Z06 oil change instructions??
Former Vendor
Anyone have a pdf of how to change the oil. I do all the work to my cars so just want to be sure i do it right
Here is the master list:
https://www.corvetteforum.com/forums...-stingray.html
Oil change (dry sump):
https://www.corvetteforum.com/forums...ump-specs.html
Thanks for this info Jontall. I was wondering same thing & prepping for my Z in the next month or so. Only question is that those instructions are for stingray w/ dry sump which should be same deal for the Z, but the specified oil capacity on those instructions is not the same as what others have posted about the Z which is 11 qts I believe but feel free to correct me.
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
I don't know about others but this is what I did. I change my own Oil. Pull both plugs and let drain until no oil dribbles out. This took a good 30 minutes. I added 9 quarts of oil including what I put in filter before installing it. I drove the car until oil temp was up to normal,shut it down and waited between 5 and 10 min. to check oil. It took another one half quart of oil to bring it up between the full and add marks. This is the best level to run it at i have been told. If I put any more than 9.5 qts It will overfill it. Good luck
https://www.corvetteforum.com/forums...cking-etc.html
