2015 Z06 Tow Hook License Plate Mount
Does anyone know if there is a Tow Hook License Plate Mount for a 2105 Z06 Yet?
I've searched and can not find one anywhere.
I'm working with Rho Plate to create one - they've sent me test fit templates and are in the process of machining the first prototypes. I'll let you know when I have more details.
2019 Corvette of the Year Winner
St. Jude Donor '15
I bought the removable bracket.....pull a spring loaded pin and you can pull the plate and mounting bracket off....easy enough to reattach....
[QUOTE=firstgear;1589324211]I bought the removable bracket.....pull a spring loaded pin and you can pull the plate and mounting bracket off....easy enough to reattach....
Where did you get this form, can you post the web site where I can take a look at it ?
Thank you !
Thank you !
St. Jude Donor '15
It's working great! Posted a few pictures in this thread:
https://www.corvetteforum.com/forums...e-bracket.html
I like how flexible the system is and it's easy to take on and off. Nice touches like the reduced neck size to avoid rubbing the grill are a plus.
Will they make a longer version of the bolt so one could leave the plate on and just screw it in ?
Nice job, I'll have to contact them !
The mounting is very flexible - you can move the plate bracket around quite a bit. I'm sure there's a configuration that would clear the cameras.
I'm not sure if lengthening the mount would help all that much, given the geometry of the bumper and the location of the tow hook receiver. You'd have to have pretty long mount to avoid hitting the bumper, splitter, etc.
