Installing the APsis front splash gaurds
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
The half hour job was an easy one. We did the job on my lift but could be done on the ground. The original guards snap off easily simply slide a screw drive up between the fender and the guard and pry out, finish by hand. Test fit the new part the only mod. I did was notch the bottom where the side skirt comes in contact. The notch cannot be cut without splintering the guard, grinding would be preferred there a fiber reinforced plastic material. The new guard slides under the factory fender splash shield at the bottom and install the original fastener back in. Drill a small 1\8 inch hole at the top into the plastic fender lip holding pressure on the guard for a tight fit, screw and DONE! There a great fit and come to the outer edge of the tire. A stone cannot get passed with out flying around a corner! Sorry the pics are from my phone my camera was in other use at the time. Well worth the wait thanks Apsis.
I have the fronts and rears. Just waiting till some extra time comes to put them on. thanks for the report!
