Callaway Z06-NEW NUMBERS HAVE NOW BEEN RELEASED!
#222
Very impressive. Especially if the cooling holds up, as I am sure it will.
#223
Thanks Chris.
So customer drops off their car and 14 days later drive away and on to track and have no heat issues on track going flat out in an A8 car ?
Sounds tempting.
Does customer get to keep all the stuff you take off the car ?
tia
Does Callaway GT3 owners/race team in Europe get a discount
Rune
Sounds tempting.
tia
Rune
#224
Thanks Chris.
Sounds tempting.
tia
Rune
Sounds tempting.
tia
Rune
#227
Received 3,787 Likes
"Ask Tadge" Producer
#228
St. Jude Donor '14-'15-'16,'19
Did you read the full article?....
Cooling - Callaway engineers recognize that a key contributor to
maximizing power is reduction of inlet air temperature associated
with forced induction. Callaway’s unique triple-element intercooler
configuration provides significantly lower and well-managed inlet
charge air temperatures than single or smaller dual-element designs.
The supercharger housing extends through the hood, thereby exposing
it to outside ambient airflow and adding an element of convective
cooling. The supercharger is visible without opening the hood, and
heat is inherently extracted from the engine compartment
#229
Yes, and I also know quite a bit about how engines work. Air charge temps aren't the Z06's current problem, as many of us have been saying since... well.. this thread started months ago. For those that are having problems, it's water and oil temps. Better cooling for the air charge will have, literally, no effect on either of those.
#230
#231
...while at the same time, increasing output torque by nearly 130ft-lbs (which is impressive!) That increased torque is going to result in increased heat, there's no way around that. And according to the text, Callaway has done, literally, nothing to address either water or oil temperatures.
Techie aside: ICEs are some of the most inefficient things we've designed. They use somewhere around 33% of the torque they produce to actually move the car. The rest of that "power" is wasted as noise and heat! So if you increase that torque/power output, you'll increase both noise (managed by the exhaust system) and heat (managed by... um... yeah.)
Now, I don't know what their engine tuning parameters are like, but I'll bet a dollar it ends up leaning the A:F a bit more than OEM. You know what that'll result in?
(A hotter running motor).
I'm sure this package is incredible and will work well for drag racers as well as the "Cars'n'Coffee" crowd. But for the guys that are driving the snot out of these Z06s at the track and experiencing heat problems, nothing Callaway's done is going to help. In fact, they're just going to overheat faster.
#232
Alcoholics Unanimous
Received 1,642 Likes
St. Jude Donor '15-'16
I was really hoping Callaway would have seized the opportunity and remedied this, as a result this package isn't applicable to me and I will pass on it.
#234
Stating that this car will be able to maintain power "lap after lap" is completely disingenuous and a complete disservice to owners putting down $18K for what amounts to only an increased sized S/C and a bunch of cosmetics with NO additional engine oil and/or water cooling mods!
I will be incredibly surprised if this car performs any better, ( and it may well perform worse given the increased hp and torque), than the stock car on a road course in summer temps. Please note I'm not talking about the out and out speed of the car; obviously it will be quicker and no doubt that is what buyers of this package want, but of its ability to lap for a full session in an HPDE.
Bish
Bish
#235
Bish
Bish
That said, I am surprised that a company like Callaway would make a claim without knowledge....so is it possible that the supercharger sticking out the hood (and dumping a lot of heat, I assume) does keep under hood temps down to the point that the stock cooling systems are acceptable?????
#238
#239
I drive the snot out of my cars, I had 24,500 miles on a 19 month old 2014 Z51 C7....I do not track as often as I would like, due to time and distance, but I do track 5 to 8 times a year. I personally know of two other people getting the Callaway modifications who track a lot more than I do.....I and one other, I personally know of, are on the Gulf Coast...so high humid temps. I do not pick up my Z06 until late August, most likely it will be toward the end of September before I am able to take her to the track. Do not worry, it is still hotter than hades in September...so we will report in after we have tracked.
#240
St. Jude Donor '10
JVP is a Callaway hater. He's been doing nothing but pissing on Callaway since they designed a blower that is exponentially superior to the one produced by his idol's at GM.
According to his profile he's a network engineer, yet he thinks that have the tag Tech contributor below his name and the fact that he gets to email Tadge a question every month makes him the authority on all things automotive.
Any assumption that he makes about Callaway tuning comes from ignorance especially when talking about leaning out the motor to make more power. In this case his bottom dollar is worthless.
I would say let the Callaway Z06 test its metal on the track....both drag strip and road course. I already know for a fact they will offer an HD cooling package for anyone that needs it. A larger radiator isn't exactly rocket science.
Perhaps it should be allowed to run a few laps before all of the "experts" at CF.com start running it into the ground.
