Anyone change out the yellow plate lights yet?
I have always changed my plate lights to a bright white an any interior lights on all of my cars.anyone have pics or vendor suggestions,i found one but they had tons of styles an i dont want to choose the wrong setup.
http://www.corvettemods.com/C7-Corve...et_p_9353.html
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
I did my license plate bulbs and the bulbs inside the hatch with DiodeDynamics.com
The license plate light lens slides, to the side and drops down. You pull the bulb out and slide the LED bulb in. Test it first before clipping the lens back into the bumper. If the bulb does not light up. Pull the bulb out and turn it around and put it back in.
Just swapped my bulbs today. Used a flat blade screwdriver (you could probably use your finger tip) and gently pushed against the right edge of the lens. The plastic lens has a integral "spring" that is easily compressed. Basically, push to the right and then pull the lens down and out from bumper cover. Unclip the harness from the bulb holder and the change the bulb...took me two minutes to do both lenses.
