Blue tape as temporary clear bra
I can't get my c7z to sun tech clear bra installer until 6/2/15. So for temporary paint protection, I applied some blue painters tape that will be in place for about two weeks. I know the tape doesn't leave any residue under normal circumstances, but are there any other complications that could arise?
If you are near a GM proving ground, some people may mistake it for a C9 that is under wraps.
Or, maybe people looking at you like you are some sort of idiot?
I had the same thought about taping the rear brake ducts on my car when it comes, on the drive home, i saw a lot of pitting there on a fairly new Z06 I saw last week.
I decided I may just use some scotch tape on the duct leading edge, as it peels off fairly easy the same day,and the glue comes right off with a little WD40,and it won't be so obvious.
Doug
Doug
Received 8,928 Likes
You could also try the green Scotch 233+ which is a little more rugged than the household blue painter's tape. With both tapes you do need to watch how dirt builds up on the edges. The adhesive is exposed slightly at the edge of the tape and it will attract dirt/dust and after a number of days in the hot sun and maybe rain will leave a thin line of dirt stuck to the car.
The longer you leave it on and the more exposed to the heat of the sun the harder it is to get the tape off.
You can see the green tape on the front of my Z in the avatar picture to the left. After a couple of years I stopped using so much and covered most of the damage susceptible areas with collision wrap which comes off easier and provides more protection.
Bill
Bill
The paint is a good idea but not sure I would leave it on for 2 weeks. Me, I would use the tape but after about a week take it off and reapply it.
Might be over the top but I don't like leaving tape on that long.
As you can see I wasn't as OCD as the white C7...
Received 2,681 Likes
2018 C5 of Year Finalist
Would any of those spray-on protective films work for a temporary fix? I'm thinking about a Museum delivery option as well and wondering what would be a good fix for the 700 mile ride home before I can get the Xpel installed?
Former Vendor
Road Warrior Plus is an excellent alternative to the blue painters tape option. Road Warrior Plus is a state of the art temporary roll on paint protection for any surfaces on your car that might be subjected to debris, dirt, tar, stones, etc. encountered whether you are on the interstate on a trip, or are headed to the track.
It rolls on like paint, dries quickly, protects with a rubbery film, and can be easily removed when you are ready to show off your perfect paint with no residual impact to your paint. Watch the video below to see just how it looks when it's on your car and how our car looks once it's taken off. I've used it for years and never had an issue.
A quart container will cover the front of a car about 5 times and costs only $39.99.
I've used it for trips as well as routinely at the track and it works great for both.
To get more information, go to www.roadwarriorplus.com
You can view a quick video of the product here:
Road Warrior Plus is an excellent alternative to the blue painters tape option. Road Warrior Plus is a state of the art temporary roll on paint protection for any surfaces on your car that might be subjected to debris, dirt, tar, stones, etc. encountered whether you are on the interstate on a trip, or are headed to the track. It rolls on like paint, dries quickly, protects with a rubbery film, and can be easily removed when you are ready to show off your perfect paint with no residual impact to your paint. Watch the video below to see just how it looks when it's on your car and how our car looks once it's taken off. I've used it for years and never had an issue. A quart container will cover the front of a car about 5 times and costs only $39.99. I've used it for trips as well as routinely at the track and it works great for both. To get more information, go to www.roadwarriorplus.com You can view a quick video of the product here: Video Link: http://youtu.be/x2nJqhQ_BKI
Former Vendor
Road Warrior has been thoroughly tested and used for years. My business partner uses it on several of his Corvettes and I use it on a couple of Nissan GT-R's, Noble M400 and other cars. It is totally safe for any car, old or new.
Alcoholics Unanimous
Received 1,642 Likes
St. Jude Donor '15-'16
Xpel Tracwrap Temporary Paint Protection Film.
Oh I forgot, I also have a big roll of 3M painter's tape that I also don't need since I installed permanent paint protection. It's one of these guys: PM me if you want it for half price. It's expensive but it cuts the workload in half.
Bill
Bill
To the OP: the more the car sits in the sun, the more glue residue will be left on the paint. Sometimes it takes more than just a good wash to get it off. A quick clay usually does the trick. When it doesn't, a fine polish does.
My experience with these has never been particularly good. I've found you need to put on many coats to get them to be thick enough to take off easily. When you inevitably do not apply enough they are a royal PITA to remove. Between waiting for each layer to dry to apply another coat and the removal of the thin areas, the time it took would not have justified their use even if the stuff was bulletproof. They do look 1000% better though.
We tried Road Warrior on my sons Corolla when we drove down from Alaska. Applied it according to the instructions and allowed it to sit in a heated garage for 2 days.
Less than happy with the results. After a few days it started to peel off in some areas and in some very small places it is still sticking 2 years later and the only way we can get it off is with a razor blade.
Maybe it didn't like the cold?? Either way, I tossed what remained and now would only use the blue tape.
Received 1,984 Likes
You will be Ok as long as you dont get the tape wet. I tracked mine with painters tape and all was ok until a wet track day.
I now use road warrior. You just got to experiment to get it on right and if it is cold set with a blow dryer. Plus you dont want to get it in any cracks or grooves.
Has Novistretch come out with a fabric bra for the C7 Z06 yet? I know they have one for the Stingray, however I don't believe it fits the Z06.
I have one for my C5 and although I don't like bras, I like the added protection it provides during FL love bug season and on highway runs. It won't stop a rock, but it will help minimize the impact and definitely keeps the front end clean of bugs, sand, dirt, etc.
bobby1999c5 (07-17-2016)
Road Warrior doesn't work especially well in the cold. It needs a heated surface to bond well, or a heat gun after application. When done like that, it works amazingly well. It doesn't take much with a heat gun to do it either. A few minutes tops. Jerry
