Anyway to keep exhaust closed
ZR1TG
I know this isn't going to be a popular thing to do on this forum but I have never liked the sound of this car during partial to moderate throttle. I really don't like it. I loved the way my Zr 1 sounded but not this one. It's ok outside the car and ok under full throttle but I find myself switching to E driving mode ( exhausts opens the latest in that mode ) but car switched between 4&8 cylinders . Just to keep exhaust from opening as much as possible
I think the 50s/60s like sound actually makes the car feel slower then it really is.
Question is ; is there a way to have a switch that either opens or closes exhaust like we had installed on c6 z cars. There are times where I want it loud for sure but lots of the time I would like to keep the other two pipes from opening up at all .
Is this possible ?
Is this possible ?
Have you tried setting your Engine Sound Management to Stealth? You do that with the car running via your Infotainment system in the "Settings" then "Vehicle" selections I believe. Try it and see if that helps, I know the exhaust will still open at some point, but I think this is the most baffled option.
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
