Fan And heat exchanger water pump relays?
I want to manually override the engine fan and heat exchanger water pump relays. Does anyone have a wiring schematic or know which relays run them.
Looking to help cool car between runs
The intercooler pump can be turned on by the HP Tuner scanner while the engine is off. This is the only way I have found so far. The fan controls in HPT scanner do not work on the C7 fan either.
I will post results if a solution is found.
