Does Anyone Know the Best STOCK Z06 0-60 and 1/4 mile Times?
As above as I seem to be getting this question quite a bit by people who don't care about the 'under 3 sec' and 'under 11 sec' answers.
I actually show it and might put the build and these times on a dash or engine plaque at shows.
Thankls ahead!
Thankls ahead!
There's no short answer to your question. It makes a huge difference in what trans, tires, conditions, settings and a hundred other things. If you really want to know you are going to have to research it on this, as well as others, if you want to be thorough.
The Consigliere
Received 5,444 Likes
Best I've seen from member posting here is: 2.8 sec 0-60. 10.42 1/4 mile. Both stock cars on stock tires.
BigNasty ripped the 1/4 mile time. Can't remember who did the 0-60, but I think he posted it in either the launch control thread or the 0-60 thread.
edit: CLHDO posted the 0-60 time.
A8=10.42 (as above)
M7= 10.90
Please do not put these numbers on a plaque for a car show unless you run the number. I put out a copy of my time slip and some road course pics for shows.
If only someone would step up and do the fast list for this section.
M7= 10.90
What changes if any to the stock Z06 did you go before you ran those times? Those are great 1/4 times!
I just put out a copy of my own time slip when I am at car shows, not the best time ever run by someone in the same car. My personal feeing is that if you want to put out "times" and you have not run them in your car then just stick with the factory spec times.
I have recorded a 2.66 zero to 60 with the PDR while on this run..... All though the PDR's 1/4 said 11.33 soooo...for whatever that is worth!
