Z06/Z07 at CoTA on 98 degree day
I instructed a M7 Z07 student at CoTA yesterday (7/5). I must say that the car is VERY, VERY impressive on track, but my purpose with this thread is simply to note that on a VERY hot day, the car of my student and other Z07 cars on track yesterday ran every session, and my student's car reached 300 degrees oil temperature (much higher than I would recommend) BUT, did not go into shutdown or limp-home mode, nor pull power significantly enough that either he or I could notice it. In addition, I will note that he chose to run Michelin PSS tires, rather than the stickier "Cup II" tires. I was astonished at the grip they provided, as I thought they were Cup tires!. I also run PSS tires on my C5 Z06 (street car) and yesterday I noticed that at CoTA my car had significantly more roll relatively to the student's Z07 car with the same tires. I will let him post suspension setting details and PDR if he chooses.
I instructed a M7 Z07 student at CoTA yesterday (7/5). I must say that the car is VERY, VERY impressive on track, but my purpose with this thread is simply to note that on a VERY hot day, the car of my student and other Z07 cars on track yesterday ran every session, and my student's car reached 300 degrees oil temperature (much higher than I would recommend) BUT, did not go into shutdown or limp-home mode, nor pull power significantly enough that either he or I could notice it. In addition, I will note that he chose to run Michelin PSS tires, rather than the stickier "Cup II" tires. I was astonished at the grip they provided, as I thought they were Cup tires!. I also run PSS tires on my C5 Z06 (street car) and yesterday I noticed that at CoTA my car had significantly more roll relatively to the student's Z07 car with the same tires. I will let him post suspension setting details and PDR is he chooses.
As long as you're following prescribed guidelines in the manual (change to 15w50 for track then change back after it), I wouldn't be overly concerned with 300 degree temps on the oil. I believe the mark for getting an oil temp warning isn't until 320. Even when/if you hit the warnings, the temperatures were chosen at levels where they're still confident that you aren't going to damage anything. Remember, they picked the thresholds for the warnings at a level where they still feel confident that they can warranty the engine for 5/100k without issue. I am curious though how fast the student was driving. We all know there are varying levels of load people put on cars at these events. Then again, more stress on the car doesn't translate in to faster lap times either always.
Given all that I have read on the forum, I was somewhat surprised it didn't overheat sooner. It ran very strong in the earlier sessions with no problems.
The SC2s were great. But, once they're gone I will try to get PSS runflats.
BTW, everything was stock. I'll try a mixture with Water Wetter next time.
Also, that is a VERY good point about the run-flats, as I run NON, and I simply did not consider this a factor.
Thanks for sharing. The more posts about this, the obvious it is that the car is sensitive to overheating and depending on the aggressiveness of the driver, the car will overheat.
It's a damn shame and let's hope GM finds an acceptable solution.
Shocked if these issues are not corrected on the 2016 which from the looks of it... there not.
why does it seem like a crapshoot where some of these cars easily overheat, then we get a bunch of guys whose cars aren't overheating, even in brutally hot conditions?
I guess 300* oil IS overheating, but timing wasn't pulled?
Thats contradicts earlier overheating stories---just very inconsistant experiences from one owner to the next?
I'll say that I personally know of 991 GT3 on PSC2 at 2:27 and MP4-12C on Trofeo R at 2:25 as pretty quick benchmarks. Both cars stock down to alignment, other than brake fluid and pads (actually GT3 was probably stock pads).
The thing about COTA is that it costs 2-3 times more than most tracks do, so few people really get to learn the course like their local track. First-timers going sub-2:40 is very good, based on what I've seen.
I've only been on COTA one time, went 2:35 in my stock Viper TA. Had a lot left to learn there!
Tony
For comparison's sake, I saw oil temps about 280 on the LS3.
I saw 286 degrees in my 2004 Z06 (stock except for BBK) then used 6th gear, cooled to 260, got back on it and went to 286 again in 2 or 3 laps and came in. I did not take times (No PDR)
Received 2,044 Likes
Scraping the splitter.
Quikag's ZR1 is on slicks and obviously with a pretty aggressive track alignment. Not really comparable to basically untouched stock-tire cars IMO.
S.
S.
Maybe the better and more experienced the driver, the less problems with overheating. Aggressive driving style doesn't get the best lap times. Aggressive drivers run out of gas, wear out tires, brakes, blow up engines, transmissions, crash etc etc
