Wheels alignment specs
When I did my track alignment, the dealer had already had the factory specs in his machine to compare with.
The printout he gives you will show you what it was, where it is now, and the factory spec is for street driving.
But remember, most dealers don't have the equipment necessary to do rear caster adjustment and that is important.
Scraping the splitter.
Here are the "Specified Range(s)" for alignment for the C7 on my latest alignment sheet.
I do not believe there is a difference between the base/Z51 C7 and the Z06.
S.
S.
