Burnt clutch
Burnt clutch
Hey there fellow members, I have a dumb question. I was stuck in very very heavy traffic and was forced to stop and go multiple times causing me to depress my clutch multiple times. After a while, I smelt very very heavy burnt clutch and saw some smoke. I pulled up on the side of the freeway to let it cool, but what I am worried about is 3 things:
1. Did a cause any permanent damage?
2. What can I do to avoid this next time?
3. How long should I wait to let it cool?
Any and all help would be great because this is a brand new car.
Thanks everyone
Thanks everyone
With both my C7s and my wife's Camaro they seemed to do this when new. I think it's just the clutch bedding in. After a bit it stops. As long as its not slipping and doesn't keep doing it past the first 1000 miles or so I wouldn't sweat it.
JWingo (03-08-2020)
If you were riding the clutch it would burn, because you were slipping it.
You should never slip the clutch like that it will shorten the clutch life, but as long as it is grabbing you should be OK
Could you give me any tips on how to deal with traffic going forward?
Sunny, something does not sound right here. How long were you stuck in traffic????
Did you inch ahead like a 100 times or so???
Let the car ahead of you move several car lengths before you move.
Have you driven a manual in the past??
Keep the RPMs just above idle and don't slip the clutch anymore than necessary.
Received 8,928 Likes
It happens. I have been stuck like that with my C6Z and other cars. My C6Z gets the clutch burning smell quite often when I am driving up on my trailer. There is only a half inch on either side of the rear tires to the trailer edge so I have to get the car on the trailer fairly straight. It has also been used to teach my two Grandsons how to drive a manual transmission so we could do some autocrossing together. One of them smoked it pretty good trying to start on a steep hill. So far the clutch has taken this kind of abuse for 6 years.
Bill
Bill
Bill
Bill
Thanks!
Bill
Bill
You should find a flat place where you can practice starts without giving it any gas. Just slowly let the clutch out until it starts to catch and soon you'll be one your way without even touching the accelerator (at about 5-7mph). If you practice that you'll get a good feel for this specific clutch and you'll be way less likely to ride it in traffic. I'm in bumper to bumper traffic every day, you'll get used to it.
In fact even the instructors at Ron Fellows C7 school in Spring Mtn teach this technique... your clutch will last longer.
Sunny, this does not apply to your situation but when I sold my '06 Z06 it had 110,000 miles and over 100 track days and it was still sporting it's ORIGINAL clutch.
And it was still flawless.
Coasting when you can with your foot off the clutch will help tremendously
The main thing is not to keep any pressure on the clutch pedal, let it all the way out don't ride the clutch pedal.
You need to learn to use the clutch like an on and off switch try to have no in between that slipping is what causes the clutch to wear.
ZR1Bob (03-08-2020)
2019 Corvette of the Year Winner
St. Jude Donor '15
I have always given my car a little gas (just above idle) when letting the clutch out. Is this bad?
OP, your story reminds me of one of my first sports cars about 10 years ago. Just brought it home, and wanted to practice a little, so I headed downtown in our small town where there were some serious hills with stop signs on the uphill direction. Of course there is only one other car on the road, but they just have to get right on my bumper at the stop sign. Still remember the smell of the clutch as I was trying to hard not to go backwards. But it was a one-time event, and seemed to do no damage. Sold the car at about 60K miles.
Regarding the Spring Mountain approach. I can release like this (no throttle) but it seems pretty slow in real-world driving. So I do end up giving it a little gas as I take off.
I find it is easier to find the friction point when the exhaust is in Sport or Track. The Z06 clutch is so light and engages so high up that it is less intuitive than any other clutch or performance clutch I’ve driven. A little practice is a very good idea. The only real difficulty I had was when I was in a very protracted stop & creep construction related situation on a steep and very long uphill grade. The low RPM stuttering tendency of this engine only exacerbated the problem. Once I put in an Attack Blue dry Nano filter the stuttering went away and made all clutch work much less problematic.
