Can you drift a Corvette C7 Z06?
CorvetteForum Editor
You hear plenty about Mustangs drifting, and Lexi drifting, and Hoonicorns drifting, but you don't frequently hear a story about a Corvette doing the smoky sideways dance.
Read the rest on the Corvette Forum homepage. >>
Much like when you played Nintendo, you have to have the secret codes to unlock drift mode (aka Track mode Race submode). Place the car in Track mode, then press the traction control button down twice within say 3 seconds, use the toggle to the right to RACE. Enjoy. Drifting the car would be much easier if it had a traditional e-brake, but with the massive HP of the Z06, you can kick out really easy.
Tanner Foust did a fine job of drifting the C7 Stingray during the American version of Top Gear in the demo of laps done with and without Stability/traction control by an experienced driver. He did beat his time with all of the nannies off, but it was very very close...
Z51Sparkie (01-05-2024)
I wondered about this. I haven't been brave enough to try it in my Z yet and was just going to ask about it at Spring Mountain next month when I am there for the Z06 school.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
If you're using either a Z or a base, I'd have lotsa real estate around me with no obstructions. Really. Because there aren't a lotta Tanner Fouts.
SilverC5inOhio (01-26-2016)
I believe just hit the botton twice turns everything off!
Nope. Have to put PTM in "Race" mode.
Please see this "Ask Tadge" response:
https://www.corvetteforum.com/forums...rack-mode.html
I'm not even old as some but I see drifting as a seriously retarded
stunt.
You would have to be nuts to drift your Z06. But I don't see where it is cool!
Question is why?
stunt.
Question is why?
bluekey28 (05-21-2021)
I will post my vids on the skid pad showing race, all off, sport one, and wet. I did this to learn each setting (note sport 2 and race have TC on so I chose race for analysis)
Question can be asked another way... Why drag race this car?
The following 3 users liked this post by Toilets:
PLEASE stop giving false information. You even posted a link where the GM engineer stated TC was still on in race mode. You want a full drift, then you do a lot more than putting in race mode. You need EVERYTHING OFF.
The other point I was making is that hitting the button twice doesn't turn everything "off".
Wow...I just returned from Spring Mountain and this is the information they taught us. The instructors said you can drift it PTM Race mode. May be even easier when set up as you suggest, but according to what we were taught, drifting is possible. Not false information unless the instructors were incorrect.
I think we may be confusing drifting with sliding the rear end. I have been with Bondurant and I can assure you that you are not fully drifting a car in race mode. Again , I will post on the skid pad to show the differences .
But HOW do you turn everything off?
Thanks in advance...
not true, single push is only straight line traction. Single push and hold will also turn on yaw control. That's the one you need off to slide around.
Also here a good video of the c7 drifting around. Pretty much the same platform so you can.
One of the exercises at Spring Mountain on a wet figure 8 course they will turn off all the nannies and you can put the car sideways and drift it.
