500 Mile Service Completed
Went to dealer Saturday morning 4 hours later Oil changed. Yes they put in Mobil 1. Also checked rear Diff Fluid it was at proper level. I asked them to check my alignment which they did it was off Dealer aligned the car with specs given below at no charge. It is lowered on stock bolts. I have a blemish on my removable top I have to bring back for the body shop manager to check out I want to ask for a new top instead of repairing and repainting? not sure how that will fly? Will post my alignment numbers later. But here is what I can share now. Any Alignment Gurus here?
Front Caster
Left 8.6
Right 8.6
Front Camber
Left -1.1
Right -1.2
Front Toe
Left 0.05
Right 0.05
Total 0.10
Rear Camber
Left -1.5
Right --1.7
Rear Toe
Left 0.00
Right 0.05
Total 0.05
Thrust Angle
0.0
Front Caster
Left 8.6
Right 8.6
Front Camber
Left -1.1
Right -1.2
Front Toe
Left 0.05
Right 0.05
Total 0.10
Rear Camber
Left -1.5
Right --1.7
Rear Toe
Left 0.00
Right 0.05
Total 0.05
Thrust Angle
0.0
Lowering will change the camber and possibly some of the other static settings. I don't see the dealer doing a free alignment when you did the lowering. It seems like you are enjoying the car and seeing it gets required service.
