Differential Fill Plug Location ?
I want to check my differential fluid level, but I'm not exactly sure where the fill plug is. Is the fill plug located where circled in this picture? If so, where is the drain plug? I can't seem to find any DIY pics for C7's anywhere.
They changed my fluid in my 2015 M7 Z06
If I'm not mistaken there are 2 plugs!!
That is your drain plug, look above that to the right, same type plug
If you have anything over 500 miles on the car, change that fluid instead of just checking it. Trust me it will need it. I changed mine at 2k miles and wished I had done it sooner. Good news is you are good after that first change, just seems the breaking in is rough on the fluid.
robertbruce (04-23-2016)
Is it a 3/8" size (looks like it is)? And do you think the below would work based on your experience?
Amazon.com: TEKTON 1491 3/8-Inch Drive Quick-Release Swivel Head Ratchet, 72-Tooth Round Head: Home Improvement
