Either I'm in full retard mode again or I have a....
defective Z06. I watched the video below on how to set the seat memory on my 2016 Z but the memory will not hold am I missing something or do I need to see the dealer.
2017 C7 of the Year Finalist
try this first.. fast forward to 30 seconds.
This turns them on and off, the door buttons set the position.
NCC-1701 (11-02-2015)
Mine is also having issues? I set a few weeks ago and decided to change my outside mirrors and steering wheel as they were off a little bit. well I did exactly as in the video but the new setting does not hold? I have a 2016 if it matters?
Ensure you have the correct settings in the Menus,
That you have the correct key fob,
And that none of the memory setting are set at one of the limit switches. (If you need a setting at the limit switch then adjust the seat to the limit, then back it off with a minor adjustment then save that setting.)
NCC-1701 (11-03-2015)
I went to settings and set both "entry" and "exit" (comfort) settings to on.
I adjusted my seat, wheel, mirrors, etc my liking and held the (set and 1) together for two beeps. When I leave the car (open the door) the seat goes all the way back and the wheel goes up to the max for exit. When I get in and start it, everything moves into position. I know you probably know this procedure already but that is the order in which I did it and mine has worked 100% so far.
Ok thanks everyone tomorrow I'll try all these suggestions.
