2014 2015 2016 C7 Corvette Stingray & Z06 ACS Splash Guard Kit @ RPI Designs
Platinum Supporting Vendor
2014 2015 2016 C7 Corvette Stingray and Z06 ACS Splash Guard Kit
It's time to protect your investment with a set of ACS wide splash guards. These splash guards protect about twice as well as the GM aftermarket pieces. These ACS C7 Corvette Stingray splash guards are made of ABS plastic and sold as a two piece front set. Available in standard black plastic or painted in Carbon Flash Metallic, any other body color and hydro carbon fiber. Please make correct color selection when ordering. Painted will take 3-4 weeks to ship out, so please be aware of the lead time when placing and order.
Item # C7-7263
Website Link : http://www.rpidesigns.com/shop/item....rd-kit-by-acs/
Item # C7-7263
__________________
Planning on orderint these...it I have a black Z07 with carbon flash painted aero, should I order the carbon flash metallic or do I really want the regular black to match the existing trim around the wheel well. Thanks.
good question and either way you can not go wrong with either choice, it all comes down to personal preference, and what color the car is. If you go with the standard black to try to match the factory wheels spats, worst case if you change your mind they can always be painted, however if you get them painted and wonder what they would look like unpainted that can not be changed. Thanks, Don
Anyone Have these?
Has anyone put on these larger ACS Splash Guards? Are you happy with them? I'm torn on what I should do here. The GM version is very narrow and provides limited protection. These appear to be considerably wider and would certainly add more protection. I have Xpel Ultra but I suspect that will start showing some wear eventually.
Thanks for your feedback.
Received 1,071 Likes
2015 C7 of the Year Finalist
I have the ACS splash guards, they are longer and a little wider than the GM guards. The extra length protects the front of the rockers. They don't look much lager than the Gm guards on the car.
asc
gm
asc
gm
Received 2,679 Likes
2018 C5 of Year Finalist
Looks great. Any chance of offering a full Carbon Flash wheel kit at a discount that includes (1) ACS Front Splash Guards, (2) GM Rear Splash Guards, and (3) GM Front Fender Spats - All painted Carbon Flash?
