Interior heat
Interior heat
Hey there my fellow Corvette fans, I noticed a large amount of warmth from underneath my steering wheel and near my pedals while driving for long periods of time. It was slightly uncomfortable and wanted to know if anyone else has experienced it? If so, is it normal and/or should I be concerned?
Mine does it as well, that motor just produces a huge amount of heat, like some have made the comment that their blowers are still hot hours after driving, mine included. I am sure you could find a way to insulate it better if it bothers you enough.
These guys and their products are supposed to be superior and should help you address your problem. I don't have the same problem you mentioned, but, oddly, my driver's side door handle gets warm! Not the same on the passenger's side.
Try this link: http://www.thermotec.com/products/all.html
Frank
Frank
NORCAL-SS,
I have never heard of anything like this before----not surprising as there is so much I have never come across. If you find the time, could you please elaborate------it sounds like something I would be interested trying out. What is the specific product; can it withstand the heat; have you had success with it before; how is it applied; etc., etc.---anything and everything would be helpful?
Thanks.
Thanks.
The Consigliere
Received 5,447 Likes
OP - it's normal.
And, just to make you feel better, it's much improved over the C6 - in which I think I could cook eggs on the floor or in the center console.
DSOMonster (11-30-2015)
Former Vendor
NORCAL-SS,
Thanks.
Thanks.
https://www.corvetteforum.com/forums...project-3.html
Although the light on the A/C does not come on, you will find that the A/C is on. Tried that and found the air to be cool alright but the A/C compressor I could hear running.
Some of the recent GM climate control systems turn on the A/C compressor when the temperature is set to minimum even though A/C is set to off but not when the temp is set to a couple of degrees above the minimum so you might try that if your controls are set to the lowest setting. It may also behave differently if the driver and passenger temp are not synched.
Yeah, heat is normal and forces running A/C much of the time. Even the driving schools, like spring Mountain, run A/C most of time.
Saps a little HP, but with the great cornering ability, should not affect times.
Only exception is the drags. Leaving the A/C will cost you a tenth. Best to use ice bags between rounds on the intake.
Very normal---gets ugly in the summer driving from Texas to Florida. The shield on the bottom of the car that covers most of the exhaust system lets it cook your rear. If it were not for the ventilated seats (with ac on bi level) it would not be something I could drive in for 18 hours at a time in..
OnPoint, your post made me laugh out loud at my desk for a few seconds!
Maybe not scrambling eggs, but hot nontheless! I had WCC install the Crazy Cowboy insulation on the C6. WCC will perform a full Dynamat insulation job on the C7 ZO6 at the end of the year.
I want to say one thing...I did not perform this mod due to interior cabin heat. I am no longer a spring chicken and have found out I like the Cadillac interior where Class and Quiet reigns supreme. Sure I love the exhaust note, but I can roll down the window! After owning a Caddy XTS, I can't see me going back to my old Camaro days, where it was ALL ABOUT exhaust notes, thumping audio systems and big smoky burnouts. Man, I do miss those days.
WCC states the Dynamat project will cut down on cabin noise and heat which will make the Wife happy! Now the girlfriend, on the other hand... LOL
I will also be installing a Corsa X-Pipe and thinking about having the pipe wrapped or coated and having the tunnel re-insulated??? I haven't gotten that far yet.
Will post pics when the insulation project is complete.
Bob,
And....unfortunately if one does what you say, you will not get the cool air out of the lower vents, but warm/hot air just like the upper vents when the A/C is off.
Its either A/C on and cool (just right) air or A/C off and warm/hot air.
