What can I expect stability control to do?
Just received my manual trans 2015. Was surprised first time I took it out and road was wet. Under any hard acceleration, back end slid right until I backed off-even in weather mode! Maybe too much dirt in system from being trucked 1,200 miles. On pavement that may have still been damp, same thing happened. After wash, yesterday, I was able to do full throttle first and second gear with wheel spin without tail sliding out. After having driven Audi R8 V-10 where there was nothing you could do to unsettle car, I am not confident the Z06 would be the same. Let's say I pull out onto a 6 lane road and accelerate hard before going totally straight. Should the electronics keep the car in line or is this asking too much? Prefer not to find out the hard way!
Unless you turn-off the Stabiltrak, it should detect any sideway movement of the rear end and correct it quickly. I experience this almost on a daily basis when I get on it on a straight stretch and feel the rear step out slightly before correcting. Without the feature, and without manual corrective action by the driver, the rear end would move wildly to the side.
Find a stretch of clear wide road to test it.
With 650tq @3000rpm, I quickly learned that you never "stab" the throttle unless the wheels are pointing straight ahead. If you want to accelerate out of a corner you have to "roll" into the throttle.
Your R8 had less than 400tq @ and at high rpms it was also AWD. So 650 to the rear only is a big change and you may have to adjust how you are accustomed to driving. You are absolutely correct in saying that the Z06 is nothing like your R8.
You can consider the R8 a powerful, graceful, strong lion and the Z06 is just a Ferocious MONSTER! Stay safe!
