Sponsored by: GEM Motorsports
Who to have install ACS rockers and front air dam?
Old 12-24-2015, 01:07 AM
Stripeknight
Stripeknight's Avatar
Default Who to have install ACS rockers and front air dam?
I purchased the ACS Rockers and Front Air Dam over a month ago for my stored Z06 and I rarely drive it as I am worried about side rock chips, who should I have install these parts?
Old 12-24-2015, 04:20 AM
flntv
flntv's Avatar
Dealer? Autobody shop? They are super easy to do. It took me 30 min to do splitter and sides and I'm no wrench monkey.
Old 12-24-2015, 10:15 AM
op z
op z's Avatar
You can skip the rivets on the visible portion of the rocker panels and put a couple extras on the bottom non-visible portion. It looks fine an can be restored to stock at a later date if desired.
Old 12-24-2015, 02:49 PM
davepl
davepl's Avatar
Received 1,500 Likes on 987 Posts
Not to pick a battle, but because these are *functional* and generate real downforce I'd be hesitant to not use all of the fasteners in the right places. Odds are you'd be fine, but since I can't tell you how many pounds of force are on them, I can't say for sure.
I did my own, they're not that tricky, but a dealership or any competant bodyshop should be able to do it given the diagram. I did mine on jackstands and the front on my lift, but should have done all three pieces on the lift, would have been much nicer and an easier job.
Also FWIW, I had 1000 miles on mine before I installed them including track days and didn't have any chips. I had cone orange on the back paint protection, but not a single rock chip. Drive it while it's depreciating!
DRLC5 (12-28-2015)
Old 12-28-2015, 02:24 AM
Stripeknight
Isn't it always depreciating
Old 12-28-2015, 07:00 AM
DRLC5
DRLC5's Avatar
I installed my rockers alone with no help on jack stands, took about 15 min per side, Just take your time, The drill bit will go through Very Very easy, I had a new bit I could actually screw it in by hand if needed, make sure you have a Bit stop, I lost mine so I wrapped tape around my bit about a quarter inch deep.
To Who to have install ACS rockers and front air dam?
Quick Reply: Who to have install ACS rockers and front air dam?
