Pulleys, which one?
Pulleys, which one?
Looking for pulley. I heard chirping anything under 12% just a waste
Figured IW only game in town. Then saw there are couple of manufacturers. What , if any are the differences. I also saw where the 18% was pulling timing. Who has done this mod. Recommendations.
Thanks!
Thanks!
my local shop put an 18 percent on my car. could not keep ait2 down even with an aftermarket heat exchanger and a reservoir plus meth. very frustrating. put standard pulley back on. making 673hp. anxious to hear about others peoples experience. car actual runs very cool now
zo6 08 (02-04-2016)
What thermostat are you running?
160' ?
160' ?
Bad Dad (02-07-2016)
zo6 08 (02-04-2016)
I know these blowers are close to maxed out, but I wonder how a 15% pulley would be (Lingenfelter sells one). I know it's not a huge difference, but would be interesting to see.
i agree due to my experience. went back to standard pulley. with all our cooling we are not seeing aits increasing like before. i enjoy the standing mile events and this car should do much better. should not be pulling timing so bad.
The Lingenfelter Stage 1 Kit produces 720 HP and 730 lb-ft of torque at the flywheel.
http://www.lingenfelter.com/product/L250580215.html
And look below, lol
Just did the LPE 720HP Stage 1 with Halltech CAI and moved up to 605HP/646tq at the wheels which puts it in the area of LPE specs. Doing another pull tomorrow with diff filter media. In for the thread as I am curious as to general thoughts on these. LPE is says they should have a drop in intercooler add-on for this kit before long. Unfortunately, I can't get a run in with this Northern weather. The red is with the AFE CAI and blue is with the Halltech...Just purchased the carbon fiber!
Thanks for the dyno. no better comparison anywhere.
Former Vendor
meth/18 pulley/intake/corsa x pipe/catted main pipes on 91 pump 122 at at the wheels on a8 car. Julios meth kit works wonders on these cars. Tuned right julios meth kit is safe (alky control)
Depending on head unit 10-15k 80-150 HP
Pulley
Meth
Expansion tank
Thermostat
Tune
Around 2500-3000 installed 65-80 HP
Both require tune and loss of power train warranty.
Edit: add 500 for E85 should help a bit
I put on the IW 9% overdrive pulley with the Halltech CAI and gained 70 rwhp and 70 rwtq peak over stock, and my IAT2 stayed low. I'm at 653 SAE RWHP and 690 SAE RWTQ.
I am curious how others IAT2's are after over driving this blower. After 4 pulls on the dyno my IAT2 was 93f in a 70f environment. We know the fan on a dyno doesn't provide as much cooling as you get when driving at speed.
zo6 08 (02-05-2016)
Thanks!
