What to do if dropped 10mm wrench between LT4 and firewall?
Well. This time it's a wrench, not a bolt.
I used a fiber optic scope to look for said wrench. No joy.
Last time I put the car up, and the missing bolt rolled, dropped on the ground. That is not working with the wrench. I have started the engine since losing this wrench and no problems.
Suggestions?
I'm worried it could interfere or get dislodged at the wrong time. Since I have no idea where it is.....looking for advice
Suggestions?
Scraping the splitter.
Tie or tape a good strong magnet to anything flexible even a piece of string. There shouldn't be too much down there a magnet will stick to besides your wrench. Use your phone camera to take pics back there. You might be able to spot it.
Thanks all
C7 x 2 (02-15-2016)
I lost a wrench in mine once. Got very frustrated that I couldn't find it -- stepped away for a few hours and spotted it instantly when I came back. Pure luck, but it's not the first time that has happened to me or other people I know.
Best of luck!
Best of luck!
You can get a borescope camera that will work with a laptop or phone to look around as well. They're pretty cheap now and are a great help looking around in spots that are hidden. You can find them for less than 30 bucks.
It worked fairly well but it isnt telescopic it just holds whatever shape you bend it to.
Good luck
http://www.northerntool.com/shop/too...FdcagQodUZkFPw
I was adjusting valve shims on my motorcycle with a very small open end wrench and it fell into one of the oil passages. Very small opening only possible solution was to turn the motorcycle upside down. Didn't do that, took the bike to Vance and Hines to build the engine and said "Oh by the way after you get the motor off the bike please turn it over and get my wrench" They did that and I got my wrench and a very very fast motorcycle
Received 1,985 Likes
Man feel your pain been there done that several times! I was never comfortable until I found it. I even had a friend come out one time to no avail.
I stepped away for a few days restarted the search and it was almost in plain sight. I have also taken parts and pieces out to help...... as I said this has happen a couple of times!!!
Received 8,929 Likes
Bill
It was right about here: Even though the magnet grabbed it good, was still hard to get out. Next time won't take so long.....
