Octane? (drag racing)
Hey guys,
As I try and figure out the complexities of my C7Z, it is becoming fairly obvious that these cars LOVE octane! I am wondering what octane everyone is using at the drag strip to get their best times? I'm also wondering if anyone is using 10% ethanol or pure gasoline only (91-93 octane)? I live in the midwest and almost all of our fuel is 91 octane at best and most have 10% ethanol mixed in. I have read several reviews that say to try and stay away from ethanol blended fuels in race applications. I have been using Torco to try and get a few octane points, but I'm wondering if it's better to find a race fuel (100 octane unleaded) station for track days? This is obviously more expensive and way more work than dumping a 32oz can of Torco in the tank.
Any words of advice. I'm guessing that the guys running mid-10's on "bone stock" cars are running higher octane? Still learning what she likes.
Is there such a thing as too much octane in these cars? Sure doesn't seem like it.
Thanks!
Thanks!
Totally a guess, but I bet these cars would relish 94.
The only way you'd know is to log a run with 92, look at the timing, and do it again with higher octane and do the same, then compare.
If the timing is the same, the higher octane (theoretically) will make you slower as it dilutes the fuel a little. But if the engine was able to take advantage of the additional octane, you'll see more timing (less retard) on the high-octane pass.
Because the key is that the right amount is perfect and more isn't better.
I don't think you're gonna get anymore power with higher octane unless you're tuned for it, HOWEVER, it might help the car from pulling timing so quickly. We only have 91 here in Phoenix...but you can get 100octane at the pump for $7.75 a gallon and 95 for 5.50 a gallon, LOL! You can also buy VP MS109 for $75 (5gal).
I think the best, most cost effective way is to use BOOSTANE. I've used it before and it does a nice job. I have read that it's a lot better than Torco. I've never used Torco...but have read BOOSTANE is far superior. It's $20-$30 for a 16oz can, which will raise a 15 gallon tank of 93 octane up to 96 I believe...or a 5 gallon tank up to 101 ish...I have to check the chart again...it's been a while...
I'm certainly no expert though...
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
DIY mix for any octane up to 105 octane.
How is this any different from Torco?
I don't think its data as nobody probably has that except for chemists. They are are probably going off of guys that do quarter mile and just trying comparison stuff.
About a day ago, Jim at Halltech had mentioned that he or some race guys say that "Torco" is marginal at best and he/they like "Toluene".
1QUICK Z, you do any research on the "Toluene" Halltech had mentioned?
Thus, the new thread...
I'm not a chemist...but from talking to people at the strip they seem to prefer Boostane these days...Even the GTR forums and Fordgt500 and CTVS forums are talking about it.
Obviously marketing...but it's been getting some attention lately...
https://www.youtube.com/watch?v=l-WmsURxC18
Interesting for sure, but not enough to convince me "why" it's better than Torco in my application. I use a 32oz can or Torco to a half tank of premium fuel (91 to 93 octane, if I can find it) and then it gets used at the track that same day. Not sure that I give it much time to "settle".
Sounds like I need to run another experiment of logging with the 2 different kinds
If you look on the can of Torco, it "should" bring it up quite a few points, but my previous tuner told me that it was probably bringing it up 4 points or so, realistically.
As ZoratZ06 said in AZ we also have that crappy 91 gas as well, probably only 84 for all we know, so that would be a nice bump being at 95, that would almost get the octane up to a real state.
And I've been in sales for over 20 years!
Octane, or more accurately, Octane Number is a measure of the sensitivity of a motorfuel to "knock" or, ignition based upon cylinder temp and pressure versus spark. Unless you are reading the CANBUS ECU output to discover when the computer begins to pull timing you have no clue what effect "octane" has on your engine other than the manufacturers recommendation. Increasing "octane" above that level on a purely stock engine (and that includes tune) is an exercise in mental masturbation. Does nothing.
1. https://www.researchgate.net/publica...end_Components
2. https://www.researchgate.net/publica..._gasoline_fuel
Ok, so I just got off of the phone with tech support at Torco. The "settling" that you are seeing is MMT. Boostane likely has this same ingredient since it is the best liquid octane booster, that is unleaded, on the market today. Boostane has a thicker (almost diesel-like) fluid that must contain these particles a little better? Here's the kicker.... this ONLY happens when it comes in contact with UV light for extended periods of time. This is the reason why both companies use metal containers to contain the liquid. So, unless you are doing this test and then putting it in your tank, this is a NON-issue. I figured there had to be a good explanation. Dang salespeople....
